It is currently Mon May 25, 2026 10:54 am
 Post subject: front bags size
PostPosted: Tue May 10, 2011 3:22 pm
i am going to be bagging the front of my luv using dhp arms. have looked through a few builds and noticed one using 2500 and another using 2600 but had to notch frame to fit them. i dont want to have a notch in the frame so wondering which bag would be best suited. will be using slam specialties RE bags so would you recommend the 5 or 6 and will it require and notching of the chassis to fit. thanks
 Post subject: Re: front bags size
PostPosted: Mon Jun 27, 2011 7:40 am
I would like to know also.
PostPosted: Mon Jul 04, 2011 10:56 pm
you can run the 2500 and not have to notch it depending on where you place your upper and lower mounts..if your runin a 4cyc then 25s r kool but i oped to run the 2600 to give more lift and keep my psi down so it rides beter...
Epic Fabrication.
KAOS
