It is currently Wed Jun 10, 2026 10:37 am
 Post subject: 1982 Luv tranny swap
PostPosted: Wed Mar 23, 2011 1:40 pm
Hey everybody.
I have a 1982 Luv diesel 5 spd which I have owned for 21 years.
Going on the 3rd set of tranny bearings at 260K miles.
Having a hard time finding some of the bearings now.
What is the best tranny I can swap for as far as bolting up?
Cutting the driveshaft is not a problem.
I have a machine shop so I can do most anything.
This is a daily driver and I need to get it on the road ASAP.
I know I have seen a post about this before but couldn't find it.
Thanks for your help.
John
 Post subject: Re: 1982 Luv tranny swap
PostPosted: Wed Mar 23, 2011 4:41 pm
There is a guy on here who also runs the isuzu site, his name is Joeisuzu. I have a feeling he'd be able to give you some good info. You might be able to pm him if you search his name. Good luck.
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Wed Mar 23, 2011 9:47 pm
Thanks for the "intro", raidersadie. :lol:
John,
I'm right in the middle of "the upgrade" on my '83 P'up. These transmissions were weak to begin with, and on top of that--they require motor oil instead of the usual 90w gear oil. That's a fact that most shops are ignorant of, so the bearings fail prematurely. I don't know if that's the case with yours, but I'm pretty certain that's what happened to mine at about 85k miles.
According to our resident Isuzu expert (on the IsuzuPup.com forum), if you use 5th gear below 45 mph, or lug it at all, it really contributes to early failure.
Isuzu redesigned this transmission for the '86 model year, and it's quite a bit stronger. The output shaft is noticeably larger, and some bearings are also larger. These later transmissions (diesel through '87, and gas all the way through '95 models) can be retrofitted to the earlier trucks with very minor modifications. I'm using one from an '87 Impulse RS Turbo, because it had a higher 5th gear.
We have a LONG topic on the transmission upgrade. It's in the "how-to" section of our forum, but it's really just a long topic that lots of people chimed in on. Eventually, I'll re-write it into one step-by-step "article". But that's AFTER I finish my own upgrade.
Basically, assuming your donor transmission comes from an '86 or later gas Iisuzu P'up or Pickup, you need 1) a good diesel 5-speed bell housing (you should have that already), and 2) a slip yoke that fits the new transmission's larger output shaft AND fits the old U-joint. There's a list of Isuzu vehicles this could come from, and we keep having to revise the list because we discover donors that we missed, or we learn that some do not fit. But I pulled three at a salvage yard, and I have two left to sell ($50 shipped). They're all from '86 P'ups and are guaranteed to fit.
I'm told the "upgrade" transmissions should last the life of the truck, if they haven't been abused.
PostPosted: Thu Mar 24, 2011 7:11 pm
Thanks for the help!
I am calling the Junkyards tomorrow if I can get 2 seconds to rub together.
May need to hook up w/ you on one of the yokes.
I really appreciate all the help.
John
PostPosted: Thu Mar 24, 2011 7:44 pm
Oops. When I said the transmission should come from "an '86 or later" I should have said "through '95.
And I meant P'ups and Pickups, and it has to be a diesel or a 2.3 gas engine. It could also come from an Impulse through '88, I think, but you're not likely to find one of those. Oh, and an early Amigo 2wd if it has a 2.3. But not an "Hombre" or anything else after '95.
PostPosted: Sat Mar 26, 2011 7:50 pm
Found a tranny at the junkyard!
Suppossed to pull it Monday.
I'll keep you posted.
John
PostPosted: Mon Apr 04, 2011 3:46 pm
Got my tranny today! Finally.
Junkyard was muddy and couldn't get to it.
88 Isuzu w/ 2.3 Gas.
Pulling it apart now.
Thanks!
PostPosted: Mon Apr 04, 2011 4:44 pm
Thanks!
Mine is in the shop getting a new bearing. Did you see the "how-to" article that shows step-by-step instructions?
PostPosted: Mon Apr 04, 2011 6:06 pm
I did. Thanks!
I split the cases and cleaned everything.
It looked great, especially compared to my old one.
What type of lube do the new ones use?
I noticed some of the links were disabled about workong on the tranny.
Still a big help, though.
John
PostPosted: Mon Apr 04, 2011 7:46 pm
I was working on it today. Those links will point to the separate articles in the topic. Some have yet to be written (Speedometer Correction, for one).
Your speedometer will now read low, if you don't correct it some way. Your original speedometer gearing should have been 6x18, but the replacement transmission's speedometer gearing would have a 5x16 ratio. To correct it, you need to speed up the reading by 6.6666667%. I bought a ratio adapter for mine. My transmission came from an Impulse, and it had different gearing. I needed to speed mine up by 12%, and I found a +11% adapter. That's good, because it was already reading a little high anyway. The seller doesn't seem to have any +6% adapters at the moment. I'll let you know how mine works out.
PostPosted: Fri Apr 15, 2011 7:23 am
Let me tell you, I am glad I read this post about engine oil in the transmission.
I had planned on changing the fluids in my transmission due to a sort of high whining noise in fifth gear. I was going to put regular 80-90 gear lube in the transmission until I read this post. This sent me to the Luv manual which CLEARLY states to put ONLY 5W30 motor oil in the transmission, and change every 30,000 miles. I must assume this oil had never been changed from the looks of it.
I put fully synthetic 5W30 in the transmission, and there is no more whine coming from the fifth gear whatsoever.
I suggest this information be posted in a more accessible place for everyone to read. This may have saved my transmission.
Thanks guys, for posting this info.
Dennis F.
PostPosted: Fri Apr 15, 2011 8:19 am
Dennis,
That's one reason for frequent failures in this transmission. I'm pretty certain that's why mine failed at about 80k miles. Jiffy Lube had done the transmission oil change several months earlier. When it went out, I failed to connect the dots, and I paid for my overhaul. Later, when I asked them to change the oil in it again, and I told them to use 5w30, they told me the couldn't do that, their computer called for 90w gear oil. That's when I decided to do it myself.
PostPosted: Sat Apr 23, 2011 11:39 am
I am doing the tranny swap. 82 Diesel to 89 gas 2.3L donor.
Got everything apart, and was going back together today, finally!
The input shaft front bearing on my new tranny is 90 MM OD.
My old one was 80MM OD.
I can bore the housing, but hate to do that if it is not necessary.
The guy at the junkyard assured me that the engine in the truck was a 2.3.
Please help if you know anything.
Thanks,
John
PostPosted: Sat Apr 23, 2011 6:44 pm
Hey Guys.
Just got this info from another member.
Wish I had it when I was pulling the tranny in the junkyard.
1/2 day of work for me and a helper.
Hope it will save someone from the grief I have had.
John
THE 90 MM BEARING IS FROM THE 2.6 MUA TRANS. ALL 2.3 AND SMALLER ENGS USED THE 80 MM INPUT MAIN SHAFT BEARING, ONE WAY TO TELL IS THE LOCATION OF THE THROWOUT ARM, ALL MUA'S HAVE THE THROW OUT ARM ON THE PASS SIDE UNDER THE STARTER AND THE MSG IS ON THE DRIVER SIDE. AND ALSO, THE MUA TRANS HAS A ROUND HOLE IN THE END OF THE THROW OUT ARM AND ALL MSG TRANS HAVE A HOOK ON THE END
ANOTHER WAY TO TELL IF THE TRUCK IS STILL THERE ALL 2.3 TRUCKS CAME WITH THE MSG TRANS, AND ALL HAD CARB,S EXCEPT THE 94 IT HAD FUEL INJ, BUT ALL 2.6 ENGS NO MATTER WHAT YEAR USED THE MUA TRANS AND HAD FUEL INJ. AND HYDRAULIC OPERATED CLUTCHS AND ALL 2.3 TRUCK ENGS HAD CABLE OPERATED CLUTCHES.
Users browsing this forum: Baidu [Spider] and 6 guests
