It is currently Wed May 27, 2026 4:27 am
PostPosted: Wed Mar 23, 2011 8:43 am
OK I need to get the horn cover off to clean the contacts of the horn switch....but I don't see how the dam thing comes apart! I don't see any screws and with it being 36 years old I don't want to start prying on stuff and breaking it!
PostPosted: Wed Mar 23, 2011 1:18 pm
Regular or Mikado wheel? Dont know about the Mikado but if I remember right on the regular wheel. Disconnect the battery push down on the horn button with both hands and twist it counterclock wise. I could be wrong since the last time I took one off was 1985.
PostPosted: Thu Mar 24, 2011 9:22 am
It is a standard truck..not a Mikado.But mine has an elongated center section..75.
PostPosted: Thu Mar 24, 2011 12:55 pm
:smt023
1990 Chevy Suburban
PostPosted: Mon Mar 28, 2011 1:28 pm
OkI was wrong and it does twist off.Thanks guys. I thought the lip wouldn't clear.
PostPosted: Fri Apr 22, 2011 12:37 am
haha how the hell does the mikado steering wheel come off? i was just checking this out today and i couldnt ifigure it out or want to break anything.
1980 Chevy LUV 4x4 Weberfied Sold
1974 Chevy LUV 4x4 Weberfied
PostPosted: Fri Apr 22, 2011 1:15 am
im wondering the same thing. my buddy has a nice grant GT wheel i am wanting to use
PostPosted: Sun May 01, 2011 1:29 am
I guess you need a steering wheel puller tool.
PostPosted: Tue May 03, 2011 6:31 pm
On a Makado steering wheel the center section pops out so you can access the bolt.
Gently pry with a small slotted screwdriver and you'll see how it works. The ring comes out and then you can get the base below it out too. Sometimes you will find that a PO has glued it together so that makes it a bit tougher.
PostPosted: Tue May 03, 2011 10:57 pm
Hey thanks a lot. I was wondering why that center cap was glued on there. I started to pry it off but was in fear that there would be no bolt haha thanks a whole bunch!
Users browsing this forum: Google [Bot] and 57 guests
