It is currently Tue Mar 17, 2026 11:03 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
PostPosted: Wed Mar 16, 2011 1:00 am
Hey jus got my luv 2 days ago 1978 55000 origanel miles 1.8 4speed literally mint condition no rust no dents and the paint is as shiny as from wen it was on the show floor 1 owner truck garage kept its whole life the owner died and I bought it off his wife for 2300!!!!! It has the temporary tag from the day it rolled of the lot lol it also had a truck topped put on the day they bought it .........ok enough about the truck here's Wat I've done so far..... torsion bars n the front are cranked all the way down its sitten rite above the bumstops the rear I've dropped 6 inches the truck is literally about 3 inches off the ground and looks sick!!!!! Also everything in the truck wrks and is there I've gotten real lucky on running across this truck I took the topped off today so this is the first time its rained in the bed in 33 yearsss!!!!! Lol im going to get sum pics up wen I get to a computer hope everyone likes it! !!
PostPosted: Wed Mar 16, 2011 8:47 am
welcome here
PostPosted: Wed Mar 16, 2011 10:23 am
hello...
PostPosted: Wed Mar 16, 2011 12:41 pm
welcome to the site, got any pics of your new luv
PostPosted: Wed Mar 16, 2011 1:50 pm
Sounds like a nice find. Welcome.
PostPosted: Wed Mar 16, 2011 6:58 pm
Yea I've got sum pics I will upload them tonite!!!!!!
PostPosted: Wed Mar 16, 2011 10:52 pm
sum surface rust but everthing is ther and mint!!!!!! rockers need sanding and repainting
PostPosted: Wed Mar 16, 2011 11:11 pm
Wow! That's pretty clean.
PostPosted: Thu Mar 17, 2011 3:07 pm
looks sharp... good find
PostPosted: Thu Mar 17, 2011 5:39 pm
looks cleannn! 8)
even the original old school center caps thats pretty cool :o
PostPosted: Thu Mar 17, 2011 6:07 pm
Nice...sweet truck.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Thu Mar 17, 2011 8:09 pm
dang man real clean, how much is it lowered?
PostPosted: Thu Mar 17, 2011 8:28 pm
It's in his first post.
PostPosted: Thu Mar 17, 2011 11:42 pm
Ok jus bought a new weber carb today should b here sat or monday but I need help Wat do I do wit the smog pump do I need it we don't have emmision laws in ky I wanna take it off but I've never messed wit one and honestly don't kno how to take the damn thing off lol any help would b great also do the make an fm radio for it mine only plays am or is there a way to change it to fm please help!!!!!!!!
PostPosted: Sat Mar 19, 2011 4:14 pm
lost cause on the tank buying a replacement
PostPosted: Mon Mar 21, 2011 3:47 am
i did an emissions delete on mine recently.. off the top of my head this is what i remember, i will try to get pics in daylight... after jury duty tomorrow.
the EGR valve is on the bottom of the intake manifold, plumbed over from the rear side of the exhaust manifold, you will need a plate to block off the egr port on the intake mani (or fid a way to plug it) and a pipe plug for the exhaust side once the EGR pipe is removed.
smog pump goes, air injection rail above exhaust side goes, VERY hard to find a correct plug for those holes!!! i made a set for mine out of 14mm solid bar, threaded and with a slit on the end for a flat screwdriver. ( i will look to figure out what the thread pitch is i want to say 1.25 but not posative.)
you will need a few vacuum plugs, etc... to close off the open vacuum ports on the intake manifold. and maybe one on the weber?
its pretty straight forward but MUCH easier if you have the manifolds removed. almost all of it but the air pump are a huge pain to get to with them on. if you have a manual for the truck it makes it easier to track down what goes where but being 30+ years old there isnt a lot to remove.
you will be amazed how clean the engine bay looks without all that junk in the way! and one less belt running off your engine (you will only need one pulley running off of the crank unless you have A/C)
PostPosted: Mon Mar 21, 2011 10:32 am
thx carb came in today soo imma give this a try ill update later thx for the repley and help again and id love to c ur engin bay if u could get a pic up
PostPosted: Tue Mar 22, 2011 9:16 pm
new carb is on.... the gas tank im waiting for the chemical to dry that will go on tomorrow....... machine shop is makin me plugs for my smog pump so i can fully remove....... tires r n the mail on the way here and ummmmmmm the bottom are jus sum more pics of the truck
PostPosted: Tue Mar 22, 2011 9:22 pm
Cool. What's the toggle switch for?
PostPosted: Tue Mar 22, 2011 11:21 pm
Welcome, very nice find and good pics.
