It is currently Mon May 25, 2026 6:01 am
 Post subject: Door and fender removal
PostPosted: Fri Mar 18, 2011 1:03 pm
Guys I ruined my drivers door and bent fender when door hinge locked up and I didn't realize it and tried to shut door.
Can anybody describe or show pics where the bolts are to make my life a little easier?
Thanks
PostPosted: Fri Mar 18, 2011 2:10 pm
hello cleaver . look inside the cab on the kick panel and youll see a plate that is held on with a screw ,the upper hindge is the same way but behind the dash right abouve your vent pull knob , take them out and pull plates out and youll see the bolts for the doors [note the hole buy the drill]
. youll have to take the headlight bezel off to get at three hidden bolts for the fenders . the rest you can see . hope this helps
PostPosted: Fri Mar 18, 2011 4:12 pm
i did the same thing the other day cuz my hinges were sooo worn out...
how bad did you bend it? do you have a pic of the damage?
i was able to bend mine back without taking anything off. i just shimmied the door back on the hinges and used a thin wide piece of metal to pry it back.
PostPosted: Mon Apr 18, 2011 11:37 pm
I have a extra set of driver side hinges from my old rusted out door hinges are in great shape if needed just pay shipping and they are yours
LIVE HARD PLAY HARDER
PostPosted: Fri Apr 29, 2011 10:34 pm
For some reason I did not get a notice for these post.I have found a different door just need to go get it.I sprung the door really bad...a local body shop owner actually went "Holy Shit!"When he saw the door..he helped me get it closed so I can drive it.I can straighten out the fender but want to get it off so I can use a hammer and dolly on it.
