It is currently Mon May 25, 2026 11:28 am
PostPosted: Fri Mar 04, 2011 6:02 pm
I just bought an 86 Trooper box but it only has a single hole in the ptiman arm. The guy at the junkyard said this was an 86 box, but the truck is long gone, so I do not know if it had round headlights. The u joint was not on the box either so I'll have to adress that issue also if this box fits. I have a sbc in the truck and hope to use the stock gm pump and make up lines to fit both the box and the pump. Any suggestions,warnings,etc that I should be aware of?
PostPosted: Fri Mar 04, 2011 10:14 pm
Uhhh, what are you driving?
PostPosted: Fri Mar 04, 2011 10:56 pm
alright... look up trooper power steering swap on the "search" amd u will fid the thread about how to do it step by step.. basically u need to adapt the steering shapt to fir the trooper box end since it is a different coupling and that is about it. really simple swap!!! and totally worth it.. i drift my luv and i wish i had power steering!!
PostPosted: Sat Mar 05, 2011 5:48 am
a 1976 Luv sbc.
