It is currently Sun Jun 07, 2026 8:12 pm
 Post subject: carb
PostPosted: Mon Feb 28, 2011 12:20 pm
After 26 years hitachi carb finally died. I have a weber that was on a luv. I got a kit with adapter and gaskets with studs. no throttle cable adapter. Anyone have one or a good picture of how they made one. My parts package says weber on it but studs are a joke. Thry are undersize. I am going to play hell finding metric studs here but will keep looking.
So if anyone can help with cable adapter I would sure appreciate it.
1980 Luv 4X4
another 1980 luv 4x4
 Post subject: Re: carb
PostPosted: Mon Feb 28, 2011 12:59 pm
I tried using different studs and the adapter plates bind. I ended up using the supplied studs.
Image There are plenty of examples here just a search button away on what people did to get their throttle brackets to work. This is what I did-
PostPosted: Mon Feb 28, 2011 3:05 pm
I have done the search but haven't hit on the one that suites my fancy. ethelkilledfred (what a handle)your stuff has been as good as any.
1980 Luv 4X4
PostPosted: Tue Mar 01, 2011 1:32 am
Thanks, I did mine as close to bolt in as possible and was how I remember we use to do it back in the 80's.
Here is what 1988Luv did, hope this helps-
viewtopic.php?f=6&t=15627
PostPosted: Tue Mar 01, 2011 8:25 am
great pictures. Thanks a lot. Should be able to work from that.
1980 Luv 4X4
PostPosted: Tue Mar 01, 2011 10:34 pm
Mine looks similar to that.
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
Users browsing this forum: Baidu [Spider] and 37 guests
