It is currently Tue May 26, 2026 1:37 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 78 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Feb 26, 2011 8:34 pm
crossfire wrote:
You have a pot to piss in or you don't, You CC or PAT it your selling or your an ass. Got a pair of nickles..... Color Me Gone from this CLICK SITE!!
bu-bye
PS... It's spelled "clique" when used in that context. I'm happy that I was able to educate you further.
PostPosted: Sun Feb 27, 2011 2:06 am
Not to get in middle of this but did you read this part-
Quote:
I offer the BLUEPRINT AND INSTRUCTION KIT.. for 55 bucks. thats all of the design requirments and patterns for fabricating the system (your basicly buying my homework)
He even offers you the option to do yourself or get a local machine shop to do it for you. Is it just me cause I don't see the problem here? Anyway good luck with your new brake system.
PostPosted: Sun Feb 27, 2011 3:09 pm
yea no idea what the sudden freak out was about....
that is a VERY fair asking price for a custom brake system! shheeeiiiittttt go to summit and tell me where your find a similar setup for anywhere near the same price!
PostPosted: Sun Feb 27, 2011 5:53 pm
Yea checked out Aerospace brakes today and was impressed that they had a kit for luv trucks. Dont know what im goin to do.
PostPosted: Mon Feb 28, 2011 11:24 am
It is a very nice set up, and am glad it's an option. The only thing is the cost. On a race truck it's fine, but on a budget street truck it cost more than what some people paid for the truck. But it's still a bargain when compared to later model Chevy brake problems, see below. Now if you have an S10 swap then your choices go up and are are a lot more from stock to just about any aftermarket brake choices and have more choices in the prices also (S10 and G bodys share the same brakes).
AC-247VRDSP CHEVY LUV TRUCK 950.00
Quote:
ITS INCLUDE:
Billet Aluminum 4 Piston Calipers
Billet Aluminum Hubs with screw in dust caps
Billet Aluminum Mounting Brackets
11 3/4 Diameter .81 Thick Vented Rotors that have been drilled, slotted and zinc plated for lasting good looks.
Grade 8 Hardware
1/2 x 3" long screw in wheel studs
Wheel Bearings
Grease seals
Hawk Performance Brake Pads
Meets All NHRA / IHRA Requirements
Prices starting at $831.00
For Street Use!
Designed for Cars Weighing Under 3800lbs
The red one is an example of it, truck cost me $500 and the blue one was $1000. I have around $2000 in the blue one now (weber carb swap, replaced fuel pump, timing chain, brake calipers and recurved dist to name a few) and around $540 in the red one (fuel pump went out).
Now my burban has a brake problem and the solution is $1500 factory brake replacement due to the computer or a $1500+ aftermarket brake swap kit. This truck goes through brakes like crazy. It seem that the brakes are too small for the weight of the truck and overheat the brake fluid getting it dirty. That causes the anti-lock system not to release the brakes and they drag. Eventually this will cause the computer to fail. I just put new pads two months ago and they are worn out again. Now the buying some time till I have some money solution is to replace my brake fluid and clean the brake system every 2500 miles. So far this is working and cheaper than a brake job.
PostPosted: Mon Feb 28, 2011 7:29 pm
Yea that is the same kit I looked at but they didn't have it on the site what came in the kit so thanks for the info. Will the bearing and rotor mount up to the factory spindles.
PostPosted: Tue Mar 01, 2011 1:09 am
I believe so. Here are a copy of the instructions and a link to instruction and it has pics.
http://aerospacecomponents.com/images/i ... _TRUCK.pdf
Quote:
CHEVY LUV
TRUCK
KIT INSTRUCTIONS
RACE, STREET, 2 PISTON AND 4 PISTON FRONT KITS ARE ALL COVERED IN THESE INSTRUCTIONAL SHEETS.
1 AEROSPACE COMPONENTS 727.347.9915
Preparing the spindle:
You will need to remove all factory braking components from your spindle and clean all mounting surfaces. Remove any old grease from spindle snout. A bare clean spindle is required before new installation can begin.
1.
Using the new caliper mounting bracket as a guide determine which dust shield holes line up and will be used to attach the bracket.
2.
Some Chevy Luv Trucks have (1) 7/16 bolt hole on the spindle. If your spindle has the 7/16 hole you will need to drill that hole larger in the caliper mounting bracket.
3.
Attach the mounting bracket with the appropriate hardware from the kit, the brake caliper normally mounts opposite of the steering arm.
Attaching rotor to hub:
Drag race kit:
Using the hub and wheel that will be used on the vehicle, determine which bolt pattern in the hub will be used. Screw in each ½-20 x 3.0 long stud from the back side of the flange using red loctite and torque to 40 ft. lbs. Make sure you used the correct bolt pattern by double checking the hub fitment into the wheel at this time.
Locate the hardware bag containing QTY (10) of a 3/8-24 x ¾ long hex head bolt and QTY (10) 3/8 internal ring lock washer. Clean the hex head bolts with acetone or brake cleaner. Make sure the surface of the hub and rotor are free from burrs or debris on the mounting surfaces. Place 1 lock washer on each of the 10 bolts. Put a few drops of red high temp loctite on each bolt. Slide bolt between wheel flange and rotor mounting flange and drop through one of the rotor mounting bolt holes then start threading into rotor. After all bolts have been started into the rotor clamp rotor into a vise (take care not to harm rotor surface in vise jaws). Then using an open end 9/16 wrench tighten each bolt and then torque with a “crows foot” socket to 35 ft lbs. (see diagram)
Street kits:
Using the hub and wheel that will be used on the vehicle determine which bolt pattern in the hub will be used. Screw in each ½-20 x 3.0 long stud from the back side of the flange using red loctite and torque to 40 ft. lbs. Make sure you used the correct bolt pattern by double checking the hub fitment into the wheel at this time.
Locate the hardware bag containing QTY (17) of a 5/16-18 x ¾ long low head bolt and QTY (1) 5/32 hex key. Clean the low head bolts with acetone or brake cleaner. Make sure the surface of the rotor adapter and rotor are free from burrs or debris on the mounting surfaces. Place rotor adapter cupped side facing down on a table (counter sunk holes facing up). Place rotor over the top of adapter with the side with tabs facing up. Put a few drops of red high temp loctite on each screw. Install each screw finger tight first then tighten all screws to 20 ft lbs or as tight as possible. Place hub nose cap side down onto table then place rotor/adapter assembly on top of hub with the counter sunk holes facing upward. Locate the hardware bag that contains QTY (10) 3/8-16x 1 ¼ long flat head screws and QTY (10) 3/8-16 Ny-lock nuts. Place flat head screws through rotor adapter and hub and thread into 3/8-16 Ny-lock nuts and torque to 30 ft lbs. (see diagram)
HIGH PERFORMANCE RACING PARTS http://www.aerospacecomponents.com 2
Final assembly of parts:
1.
Pack grease into the inner and outer wheel bearings and put a very light amount on the grease seal lip. Place inner bearing into the hub and then install the grease seal into the hub.
2.
Slide hub/rotor assembly over the spindle shaft and install outer bearing then the tanged washer then nut lightly snug the nut.
3.
Adjust the bearings by spinning the hub assembly while tighting the nut, ideal is to have zero lash and slight drag felt when rotating the hub assembly.
4.
Place the spindle nut locking ring over the spindle nut lining up notches in ring with cotter pin hole in spindle shaft if the hole does not line up just spin the lock ring only until you can achieve alignment then place cotter pin through hole and bend the legs to prevent the spindle nut from loosening.
5.
Install brake caliper to the mounting brackets with the bleeder screw above the brake line port so the bleed screw is to the highest point. You will need to use the 3/8-24 x 1 1/4 hex head bolts. Be sure caliper is centered on rotor within .050 of an inch by using the supplied shims. Torque to 35 ft-lbs.
6.
The inlet port of the brake caliper is 1/8-27 pipe thread. The stock hoses will not work. Aerospace Components sells line kits to fit most applications.
7.
Drop the brake pads into the calipers and secure them with the pad retaining bolt and nylock nut. Be sure the bolt extends through the locking feature of the nut. This nut should be replaced every time you replace your brake pads.
8.
Make sure the brake pads are the only thing touching the rotor and that the rotor spins freely. This is a fixed caliper system and the bracket and rotor will have minimal clearance, but should not touch.
The caliper must be parallel to the rotor. A different number of shims may be required to achieve this for one caliper.
Final Check:
1.
Make sure all fasteners are tightly loctited in place.
2.
Make sure all fittings are tight
3.
Check for wheel clearance between brakes and wheels as well as brake lines and wheels/tires.
3 AEROSPACE COMPONENTS 727.347.9915
HIGH PERFORMANCE RACING PARTS http://www.aerospacecomponents.com 4
Brake Lines:
The intake port on the brake caliper is 1/8-27 pipe thread (1/8 npt). Banjo style bolts and fittings will not work with this kit. Wrap the pipe fitting with a couple turns of Teflon tape before installing in the caliper. The fitting should screw in about 2 turns by hand then use a wrench to finish tightening it up. When installing the brake lines make sure they are positioned where they will not contact any moving parts. Check that the brake lines are long enough by jacking the front end of the car up and turn the steering from wheel lock to wheel lock making sure that the lines are not being pulled on at any time. If there is tension on the brake line at any time a longer line will be required.
Brake Fluid:
Dot 3 or Dot 4 fluids are recommended for best results, DO NOT use DOT 5 or any fluid that contains silicone. Many Dot 5 fluids contain silicone which will cause damage to the piston O-rings and will also damage most master cylinders. Chose a good brand fluid, we have always had good luck with Valvoline and Castrol brands.
Master Cylinder:
The master cylinder requirements vary depending on front/rear brake combination. If you are using 4 piston calipers on the front and rear it will require a master cylinder with a minimum bore size of 1 1/32. Call 727-347-9915 if you have any questions about your current setup.
Bleeding the System:
An initial gravity bleeding is recommended to remove most of the air in the system. This is accomplished by filling the master cylinder with fresh fluid and opening the bleed ports. Leave the top off the master cylinder. Fluid will flow into and fill the calipers. Be sure to keep fluid in the reservoir to keep air out of the system. This process will take some time. A final bleeding is accomplished by firmly pressing the brake pedal and having someone open the bleed port until the pedal goes to the floor, closing the bleed port before the pedal is lifted. Do not pump the pedal while bleeding. This only foams the fluid and prevents proper bleeding. Repeat this process for all brakes until pedal is high and firm. Be sure no air bubbles come from the calipers.
Brake pad bedding:
New brake pads require a bedding process. This bedding procedure starts by pumping your brakes at a very low speed to ensure proper brake operation. Make a series of hard stops at progressively higher speeds. Continue this process until brake fade is felt. Park the car and give the pads a chance to cool completely. Improper pad bedding results in glazed pads diminishing stopping ability. Brake pads should be checked regularly. If pads are wearing evenly, they can be used almost down to the packing plate.
PERFORMANCE RACING PARTS http://www.aerospacecomponents.com 5
Getting the right ratio:
In order to get the correct ratio for your Aerospace Components braking system, a few measurements must be taken. First, remove the old master cylinder. Measure from the center line of the pivot point “P” of the brake arm to the pivot point of the master cylinder rod to get length “B”. Next, measure from the pivot point of the master cylinder rod to the center of the footpad to get length “A”. Finally, divide length “A” by length “B”. This will give you your pedal ratio. The recommended ratio should be 7:1. For example, if length “A” was 14 “ and length “B” was 2”, then 14/2=7.
HIGH PERFORMANCE RACING PARTS http://www.aerospacecomponents.com 6
WARNING:
ALL AEROSPACE PRODUCTS ARE FOR OFFROAD USE ONLY AND ARE NOT INTENDED FOR STREET USE!
SAFETY IS A REQUIREMENT!! TO ENSURE SAFETY A PARACHUTE, ROLLCAGE, 5 POINT HARNESS, D.O.T. OR SNELL APPROVED HELMET, FIRESUIT AND ALL OTHER NHRA OR IHRA REQUIRED SAFETY DEVICES SHOULD BE UTILIZED AND KEPT UP TO DATE. ALL RACERS SHOULD HOLD A VALID LICENSE FOR THE CLASS IN WHICH THE VEHICLE IS DESIGNED TO RUN. PROPER INSTALLATION OF COMPONENTS IS OF THE UPMOST IMPORTANCE. MAKE SURE THE PERSON INSTALLING ANY COMPONENT ON YOUR RACE CAR IS FAMILIAR WITH THE PROPER INSTALLATION OF THAT COMPONENT. Aerospace Components is not liable for any damages or injuries that may occur due to incorrect installation of parts or components!
Please remember, racing pushes all components that make up a vehicle to their max stress levels. When any part or component is pushed to the max its chances of failure rise dramatically. This is why race parts and components carry no warranty. This is also the same reason why safety gear should be used at all times and why fastener and part inspections should be performed regularly. By installing any Aerospace Components parts you agree that Aerospace components can not be held liable for any damages or injuries resulting from part or component failure. Remember this is racing…. parts break, systems may fail so be prepared mentally before a race. Know where the chute handle is, know where the kill switch is, make sure your safety restraints are tight and have a plan in mind for when things go wrong. Never place the transmission into park, reverse or use the transmission brake to stop a moving race car; if you try YOU WILL CRASH! The best way to stop a runaway race car is to release the parachute and kill the ignition. Please be safe at all times and hope for the best but plan for the worst.
MOTORSPORTS ARE EXTREMELY DANGEROUS
AND MAY RESULT IN SEVERE INJURY OR EVEN DEATH.
RACE AT YOUR OWN RISK!
HIGH PERFORMANCE RACING PARTS http://www.aerospacecomponents.com 7
PostPosted: Wed Mar 23, 2011 7:40 pm
I had a line on a cheap used set of aerospace racecar setup. I called aerospace on how much it would cost to "upgrade" to the street version... It will cost more than buying it new... That was when they were less than $600 a set.
PostPosted: Mon Aug 15, 2011 2:11 am
dr_frankenstein56 wrote:
well im trying to offer some goodies for these trucks thats within the average rodders budget. if you guys have any suggestions Im all ears. if the prices seem to high, i can work with ya... just lemme know.
soon available will be:
pre cut driveshafts for POWER BY ACE V8 mount kits and popular automatics with S10 rears.
Power Steering Kits.
power window kits
complete retrofit AC systems and restored original components
Buick V6 Performance parts
thanks
A.j.
Pm power window kits~
PostPosted: Wed Oct 12, 2011 11:58 pm
77pumpkin wrote:
Cody_79luv wrote:
ah that would be great to have, if i hadnt sold my smallblock luv i wouldve definitely bought that. the 6 lug wheels on the front drove me crazy lol. now somebody needs to make a complete bolt-on 4 link for the short and longbed, plus a control-arm and drop spindle kit for those of us who like to drag the frame :ebiggrin
just buy someones used s10 drop spindles ... ive seen several in my area's craigslist listings for an average of $50. maybe a small discount would be offered if you knock off the stock s10 spindles from the kit?
@ dr_frankenstein56 ...
1.) does the basic kit include or not include calipers
2.) how would the basic kit work if using DHP lower control arms? would i just need to use the upper balljoint adapters? i will be in the future doing hydraulics and intend to use Mike's lower arms with stock balljoints. should i get them with s10 balljoints? or stock luv balljoints? id be very interested in the kit in the future when i get the money to do my suspension
PostPosted: Fri Oct 14, 2011 2:45 pm
Ok I am buying thes set.. Buy I emailed the guy that makes thim and I havent heard a work any one no a easyer way
PostPosted: Sun Feb 05, 2012 9:12 pm
Any update with the kit. I'm wanting to buy one.
PostPosted: Sun Feb 05, 2012 9:52 pm
I have no idea what has happened with him. I have a pm to him on another matter from July 2011 that is still sitting in my outbox. Hopefully, he has just forgotten about us...
PostPosted: Mon Feb 06, 2012 8:12 am
last i heard from him was last May, didnt realize its been so long.
nothing new on his youtube channel since june '11...
his profile doesn't say when he was last logged in either, kind of odd...
anyone who knows him personally who may know whats happened with him?
PostPosted: Mon Feb 06, 2012 12:34 pm
I got an email from him this morning.
Quote:
We currently do still market the kits, but we do not sell the kit as a stand alone item due to liability reasons. We now just offer the kit as something our local shop can fabricate and install.
Our legal department kinda gave us the hammer after we had an issue with another kit, which is why I dont activly pursue sales of kits on the Luv Truck website.... its been a major headache.
If anyone in his local area wants his contact info for his shop to do an install, PM me.
PostPosted: Sun Feb 19, 2012 1:29 am
im looking to buy the parts needed to finish my five lug swap i have the spindles rotor and break calibers just know tryn to buy the rest of what its needed
PostPosted: Tue Apr 03, 2012 2:11 pm
i am still trying to buy a 5 lug swap i have emailed the guy that sells them on here but got no reply back if anyone has his number or any additional info or something for sale please let me know thankyou
PostPosted: Tue Apr 03, 2012 3:18 pm
I'm locking this thread since the author is not selling the kits anymore. Contact Wicked Mayhem if you want a kit. He's making some.
