It is currently Mon May 25, 2026 4:52 pm
PostPosted: Sat Feb 26, 2011 7:37 pm
Ok after I replaced the fuse box and the fuel gauge sending unit with a replacement and the gauge reads about what i figured should have been in tank as long as its just sitting loose on the top of tank but as soon as i put a screw into the mix gauge slams up to beyond the full mark and stays there till you remove screw, what the heck.......?
PostPosted: Sat Feb 26, 2011 9:49 pm
possible ground problem???
not sure thats pretty weird.
PostPosted: Sun Feb 27, 2011 9:57 pm
Nope not a ground issue and not a ghost either a jap that couldnt read color code on wiring diagram the donor truck had same color wires but reversed apperantly took a gamble today and reversed the wires and what do you know works now,
