It is currently Wed May 06, 2026 12:54 pm
Post new topic Reply to topic  [ 141 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sun Jan 30, 2011 2:07 pm
:signiagree whats the update? :popcorn:
red vs blue
:smt067 :tfrag: :impact: :ctf2:
PostPosted: Mon Jan 31, 2011 11:22 pm
No i cant get the shaft from the trans to slide into the motor.....
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Mon Feb 07, 2011 7:18 pm
Well the luv is still down and not working yet....But i got a new toy!! w00t!
Ok here are some pictures i was messing around at the creek today.
These are crappy cell phone pics...My sister was taking pics with her camera but it died at the end so i got these to show for now.
PostPosted: Fri Feb 11, 2011 8:01 pm
I've had some be a pain for a bit but never had one I couldn't eventually get to together. If you have a Micrometer you might want to check the tranny shaft then measure the pilot bering in the Crankshaft. Make sure there are no burrs on either component. Are you getting all the way together and stopping at that point or is it not even going through the Clutch? If so the re-align the clutch and give it another try. I haven't read back through all the post but did you put the original crankshaft back in the engine when you rebuilt it or is it a new crankshaft? I'm just trying to bounce a few things around to see if any of these work. Let us know. Good luck
By the way, looks like you had a good first trip in the blazer.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon Feb 21, 2011 1:57 pm
mine was a bit of a pain to get in too. you gotta make sure the tranny and shaft are lined up just right for it to slide in smoothly. took me and my dad giving it a bit of push-realign-push-realign-final shove... to get mine in. :lol:
PostPosted: Tue Feb 22, 2011 12:35 am
Wow after i posted these picture of the blazer my pass got changed or somthing so i had to make a new account...I am about to get to work on the luv again....Also i painted the blazer and it runs good....I am prob gona sell the blazer to get a newer/nicer 4x4....
Also there was an idea thrown out of a solid axle on my luv....Toyota axle swap in front with the stock motor and tranny from the luv...Or a 350/350/np205 with chevy half tons on the luv...This was all ideas a friend of mine was telling me to do! so we will see hwat happens guys! :esurprised
PostPosted: Tue Feb 22, 2011 9:31 pm
Ok i got my account back...
As for an update all i got to do it get the motor attached to the trans and it should be good to go.
8)
PostPosted: Tue Feb 22, 2011 9:34 pm
8)
very nice 8) get that sucker goin! i just threw a weber on mine. much better :twisted: big recommendation lol. i was thinking about the toyota axle swap too
PostPosted: Tue Feb 22, 2011 10:18 pm
8)
Well i just went and bought a 1975 k5 blazer....I should have invested the money into the luv.....I got side tracked from the luv because the blazer is 4x4 and running! Then i drove it to church...OMFG gas milage sucked....So i got to get the luv running..And sell the blazer probably..
PostPosted: Wed Feb 23, 2011 12:39 am
chrisquested wrote:
8)
lol clean the blazer up the best ya can and try to get what u have into it out of it. then invest it in the luv!! maybe a trooper 5 speed w/t-case?
PostPosted: Wed Feb 23, 2011 1:34 am
I only paid $1400 for the blazer then spent about $400 on misc parts....And i can prob sell it for about $2000-$2500 pretty easy....
But if i did anything to the luv it would prob be a toyota axle's front and rear with 4:10 gears 5 inch lift and 33/12.50/r15 with the luv motor and an r1 carb set up, header with 2.5 inch exhaust, racing seats with 5 point harness and a roll cage.
But once i sell the blazer i got to find a dif car/truck so i can haul my 8 month son around...
PostPosted: Wed Feb 23, 2011 3:13 am
ahh. indeed family comes first. but that sounds like a solid build plan :smt023
PostPosted: Wed Feb 23, 2011 12:30 pm
Yea i figured with this set up i could drive it as a daily driver and get good gas milage and off road it at the same time.
(The dream luv)
This is what i would want to do if i do try to make the luv a real 4x4.
Motor specs:
Bored 30 over
head shaved 20 thousand
header
2.5 inch exhaust
r1 carb set up
electric fan
Transmission and axles:
Either leave the stock 4 speed or swap to a 5 speed.
Toyota axle front and rear with 4:10 or 4:56 gearing.
Tires/rims:
15 inch aluminum wheels.
33/12.50/r15 or 35/12.50/r15 (i would rather stay with 33s)
Lift:
All spring lift/No blocks.
Rancho 9000 shocks.
Dual steering stabilizer.
Interior:
2 bucket seats with 5 point harness.
Roll cage.
And then i would be done for now.
PostPosted: Wed Feb 23, 2011 4:44 pm
so far im thinking my dream build is gonna consist of (to make it more streetable and driftable) i would love a built 4x4 but i have dirtbikes to go beat the hell out of i need my truck to get me to work!
the dream...
*engine
G180 block.
g200 head (bigger valves and lower compression for higher boost).
impulse forged pistons, rods & copper head gasket
eletronic ignition and megasquirt ECU
custom intake w/fuel injectors
high pressure fuel pump and lines
turbo exhaust manifold with wastegate dump into downpipe.
t3/t4 or t28 turbocharger (10lb+ boost a bit more once its dialed in completely)
*drive
5 speed swap
possible conversion to 2wd W/impulse 3.9 LSD
*interior
race seats
fiberglass dash
partial roll cage
(currently wiring up my stereo.. not much but eh. 10" sub between/behind the seats and an 8" sub under each seat, w/6" door speakers and 600w amp. in a luv it should be more than enough for my dubstep needs X^D
one of these days lol.
i guess we will see how eachothers projects end up! keep with the updates, i will try and do the same.
PostPosted: Wed Feb 23, 2011 7:37 pm
Alright man sounds good and if my luv was a 2 wheel drive i would prob do somthing like you but since i got the 4x4 i wanna run it as a 4x4.
PostPosted: Wed Feb 23, 2011 9:03 pm
damn idk man it just snowed and rained so we got some nice ice under snow... the 4wd came in really handy on a couple of those hills X^D 2wd left me spinning my tires going about 3 Feet a min.
we will see what parts i can come across at a lower price X^D
PostPosted: Wed Feb 23, 2011 11:08 pm
Well i love 4x4s....I just painted my k5 blazer bright yellow today here are some pics of it.....
SO i am going to try and sell the blazer since i made it a little more prettyer....If i sell this thing i might invest the money into the luv or an integra....hmmmmm
PostPosted: Sun Feb 27, 2011 2:04 pm
the vehicle of choice for the attack on the banara republic XD :ebiggrin will blend right in :lol:
PostPosted: Sun Feb 27, 2011 2:32 pm
DUDE! Check out that rear tire!!! Missing some tread there... :lol:
My Rides:
2002 Mazda B4000 4x4
1978 Chevy LUV - Sold :(
1990 Kawasaki EX500
2008 Yamaha TTR230
PostPosted: Sun Feb 27, 2011 3:03 pm
some? like half :lol: how'd that happen??
BANANA...
