It is currently Sun Jun 28, 2026 8:59 am
PostPosted: Fri Jan 28, 2011 1:36 pm
Ok i am outside right now trying to get everything going onto my truck and i got a problem! i do not know were this little plate/spacer thing goes....
It is in the pic i got it bolt on with 1 bolt look at where the flywheel is suppose to go. I got brand new clutch set turned fly wheel i am trying to put this motor in today so please respond quick who ever can thanks alot!
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Fri Jan 28, 2011 2:17 pm
I cant get the pilot bearing out either for some reason....Does anyone know how to get the pilot bearing out?
PostPosted: Sun Jan 30, 2011 11:01 pm
I think the plate/shim goes between the flywheel and crank.. To get the pilot bering out. A slide hammer will get it out. If u don't have one, pack the end of the crank with axle grease the drive a rod the diameter of the inside hole of the bearing. This will force the bearing out with hydraulic pressure. Good luck.
1980 4X4 LUV
PostPosted: Sun Jan 30, 2011 11:47 pm
I just went and rented a bearing puller and a slider hammer. going to get that dam thing out tomarrow and put it in the truck i hope...
PostPosted: Mon Jan 31, 2011 4:15 am
Rick is correct that the shim goes between the flywheel and the end of the crank.
PostPosted: Mon Jan 31, 2011 8:01 pm
Wow i put it after the flywhell dam....is this gona matter or do i gota pull everything again............................
Users browsing this forum: No registered users and 70 guests
