It is currently Sun Jun 28, 2026 12:33 am
 Post subject: MSD PERTRONIX installl
PostPosted: Mon Jan 24, 2011 7:10 pm
Just wanted to see if anyone had done the MSD 6A box and Pertronix combo. I finally broke down and tackled this project. Question if you did do this combo did you use any of the negatives on the coil itself? I removed everything from inside of coil and only use wires from the pertonix straight to the MSD box and the thing runs fine. Am I going to f something up by not utilizing the negatives on the coil.
Just wondering! So long points though!!!!
OX
PostPosted: Tue Jan 25, 2011 3:05 am
You can Google the MSD 6A model number and get a downloadable installation sheet with all of the installs from points to mag pickups. Thats what I did.
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
PostPosted: Tue Jan 25, 2011 9:58 pm
I did that exactly the way it said but can i eliminate the ground on dizzy itself? It runs with out it but will i jack it up not having that ground hooked up? Im thinking if the MSD box is grounded and its grounded through the pertronix then it should be good?
Users browsing this forum: Bing [Bot] and 62 guests
