It is currently Wed Nov 26, 2025 12:15 pm
PostPosted: Fri Nov 05, 2010 4:30 pm
I'm about to try and smog my truck. I was wondering what common problems have been had from any California Luv owners? Any and all problems with solutions would be a great help to me and hopefully any other Luv owners here.
1974 Mikado 4x4 50,000 orig. miles
PostPosted: Fri Nov 05, 2010 10:13 pm
Not sure Im over in Live Oak I ripped all mine out! Im military guy registered it back home. If your missing anything let me know i kept it all, had the room so what the hell figured someone else in Cali might need it.
PostPosted: Fri Nov 05, 2010 10:15 pm
By the way any LUV items you might need the Pick an pull in Redding is a gold mine. I pulled a 5 speed up there and the choice of about three. Everything down in the valley is stripped or dont have them.
PostPosted: Fri Nov 05, 2010 10:34 pm
My brother in law and my mechanic lives in Live Oak. He can probably help you with your problems for cheap. PM me if you need help. He could probably helpyou this weekend. Lives off of P st.
PostPosted: Sat Nov 06, 2010 8:17 am
...thats good to know. im moving to Lakeport in January and Redding isnt but about an hours drive. if even that
PostPosted: Thu Dec 23, 2010 11:40 pm
do u have the cat and charcoal can ? hotrodcool2@gmail.com
PostPosted: Mon Dec 27, 2010 2:36 am
I haven't had any real problems once I got the truck tuned up and running good. I got it nice and warm, ran it down to about 1/4 tank and put in a fuel system cleaner (full bottle) and drove it until almost empty then filled it up and smogged it.
PostPosted: Tue Jan 11, 2011 7:28 pm
I had my Luv smogged a couple of weeks ago. On the gas cap, there's a rubber seal under the cap. Mine has 3 large cracks in the seal. It still passed, but the smog guy said that's a common thing that needs to be replaced on older vehicles.
PostPosted: Wed Jan 12, 2011 1:17 am
Zane, I end up having to replace the cap every time for smog...
PostPosted: Sat Feb 05, 2011 11:24 pm
I just tried to get my 79 4x4 Mikado smogged a few days ago here in California,emissions were great but it failed the Fuel EVAP pressure test. Could it just be a bad cap? Is the dude supposed to stick the instrument into the open gas tank or just wave it in front of the closed cap?
PostPosted: Sat Feb 05, 2011 11:38 pm
The smog guy usually hooks the gas cap up to a device to check it and make sure it seals right. That's been my experience anyway. I'd buy a new cap and check hoses and system for any leaks. Good luck
