It is currently Tue Jun 16, 2026 2:18 am
PostPosted: Tue Dec 07, 2010 10:49 am
Hi brothers, I've bought a LUV I'm swapping it with an 94 cavalier z24 3.1L engine. Almost is finished.
I have a question.
Do you know where are all the VIN numbers of the LUV?? 'cause I think my LUV is built from two or three LUV's haha, and I wanna know if the title I have is the original from my LUV.
Thanks a lot.
Sorry if my english is bad!.
See you.
PostPosted: Wed Dec 15, 2010 10:11 pm
Should be just below the door striker on the drivers side.
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
PostPosted: Thu Dec 16, 2010 1:06 am
There is also one body stamped under the cowl panel...
PostPosted: Sun Dec 19, 2010 11:56 pm
Ok i can see those 2 numbers, but anyone knows where is the chasis number?
PostPosted: Mon Dec 20, 2010 9:57 am
In front od the fuel tank
PostPosted: Mon Dec 20, 2010 11:55 pm
Thanks! I'm gonna check those three numbers, are they all??? or one more?
Let me finish the swap and I will upload some pictures!
C ya
PostPosted: Tue Jan 11, 2011 10:41 am
Hey how are you??
I couldn't found the number under the cowl, I'm not sure where it is...
PostPosted: Tue Jan 11, 2011 5:26 pm
You have to unscrew the cowl - it is the long piece with vents that runs along the bottom of the windshield.
The VIN number will be on the driver side stamped into the cab body.
The chassis number is on a crossmember by the gas tank. Harder to locate due to the dirt, etc.
PostPosted: Wed Jan 19, 2011 10:18 am
hey what part of mexico are you in?
A.j.
PostPosted: Thu Jan 20, 2011 1:40 am
I'm from Chihuahua Mexico!
PostPosted: Fri Feb 25, 2011 11:02 pm
Hey tomorrow i'll finish my luv, i'll upload some pictures for you!
PostPosted: Sun Feb 27, 2011 2:37 am
PostPosted: Wed Mar 02, 2011 9:24 pm
I was wondering that too. Good info guy's and NICE pics ethelkilledfred.
