It is currently Mon May 25, 2026 11:45 am
 Post subject: 81 luv 4x4 diesel lift
PostPosted: Thu Dec 30, 2010 12:22 am
anyone found body lift for diesel? all ive found say will not work with d iesel motor. i was wanting 3 inch lift and cut the fenders,try and get some 33s under there.this truck was wore out 10 years ago on a ranch so im not worried bout cutin on it. any info appreciated.
PostPosted: Thu Dec 30, 2010 1:09 am
Can't imagine why a diesel would be any different with regard to the body lift. Folks at IsuzuPup.com have done it. You will need to do some of the same stuff that a gasser would require--but nothing special for the diesel except maybe extend the fuel return line (not present on gassers).
PostPosted: Thu Dec 30, 2010 8:18 pm
thats what i thought. performance accesories seems to be the only one who makes one. but it says lift wont work with diesel motor. ill keep searching forums someone has had to lift a luv diesel.
PostPosted: Fri Feb 04, 2011 3:31 pm
other than that fuel return line, and maybe some glow plug wiring, i don't know of anything different.
other than the starter housing, i know the trans is 100% the same.
im thinking they couldn't find one to test there lift kit on :lol: :lol:
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
