It is currently Mon May 25, 2026 4:23 am
 Post subject: Areospace Brakes ?
PostPosted: Thu Dec 16, 2010 11:42 pm
I would like to know if anyone out there has installed the Areospace front brake kit on their LUV trucks and if so how much of a bolt on is it ? I'm looking at the Pro Street Kit AC-247VR. Also if you had any other problems with the conversion like brake lines, that sort of thing ? What I would really like to hear is, how much you like the way the brakes work .
 Post subject: Re: Areospace Brakes ?
PostPosted: Tue Dec 21, 2010 8:52 pm
i'm using the strip setup front and back and it was a simple bolt on.
PostPosted: Tue Dec 21, 2010 9:57 pm
I have never herd anything bad about them from those who run them.
PostPosted: Wed Dec 22, 2010 1:34 am
Thanks for the reply. If you have any pics of the brakes I would sure like to see them. Have you run with them yet, or not? Thanks, Brian
PostPosted: Sat Jan 01, 2011 9:04 pm
The first time we used the Aero system they were put to the test.
Crossing the finnish line at 120mph Phil realized the throttle was stuck and before he knew it he was at the return road turn off. The good brakes made it possible to stop in time.
The problem was a throttle blade was missing the screws on the bigger carb we were testing
and this jammed the throttle wide open.
Our old carb was installed and he made another run. Crossing the finnish line at 119mph the
throttle was found to be stuck wide open. This time Phil was unable to slow down enough to
turn on to the return so he turned on to the sports car track. The corner people were a bit
tic!
The fiberglass firewall insulation had not been removed and it had jammed the pedal wide open. The Aero brake system saved the day for sure.
Mr.T
PostPosted: Wed Jan 05, 2011 11:37 am
It was great to hear how the brakes worked for you that day, sounds like it may not have gone so good if you had mediocre stopping power. Thanks for the reply, I need to hear these things before I go out and spend that kind of money. I'm finding out that LUV truck guys are quite a cool group that seem to have this strong bond and help each other out. Thanks again.
PostPosted: Wed Jan 05, 2011 1:07 pm
I have a question, I see that they have a street kit and a strip kit at aerospace. Would the strip kit work for a street truck that had limited street use? My truck is only driven for pleasure and not daily use.
Thanks
PostPosted: Wed Jan 05, 2011 6:25 pm
The drag race setup works well on the street I have over 500 miles on them and no problems yet.
Here are a few pics.
PostPosted: Wed Jan 05, 2011 10:54 pm
Cool, thanks for the pics too.
PostPosted: Thu Jan 06, 2011 7:03 am
No problem. If u need pics of anything just message me. I've mini tubbed and notched the frame on this one.
PostPosted: Sat Aug 18, 2012 3:21 pm
do they make a 6 lug kit??
PostPosted: Sun Feb 03, 2013 11:50 am
whats the stud patern PCD ? as in is it say 5 in 120mm ?? and what did you do to fit the rear kit ? im looking to do simler but would like to keep the factory diff housing and front spindels im all so looking to run coil springs front and rear dose any one know any kits ? I am willing to run a 4 link or wats link set up :)
Users browsing this forum: Google [Bot] and 16 guests
