It is currently Tue May 05, 2026 11:46 pm
 Post subject: which weber?
PostPosted: Fri Dec 17, 2010 6:09 pm
which weber model (s) can i use for the luv.
and which are the manual choke?? i would prefer to go with manual choke. simplify it, and more like my bike.
also.. adapter plate pics?
 Post subject: Re: which weber?
PostPosted: Fri Dec 17, 2010 6:14 pm
and what model cars had the weber im looking for stock for me to find in a yard
would i be able to wire a switch to an electric choke?? run from Battery -> Fuse -> Switch -> Carb
to turn it on or off with a switch manually. if i cant find a manual choke.
PostPosted: Sat Dec 18, 2010 8:13 am
See if this helps-
viewtopic.php?f=5&t=23881&p=175246&hilit=used+weber#p175246
If not check here:
* Search + Used Weber =
search.php?keywords=used+weber&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
Holley/Weber 5200
PostPosted: Thu Dec 30, 2010 12:05 am
got my new weber 32/36 DGEV today :twisted: , full kit with everythign i need, putting it on in a couple days when i have time
PostPosted: Thu Dec 30, 2010 2:39 am
Cool, your going to love it, post some pics if you can.
Don't know if you seen this, hope it helps:
PostPosted: Thu Dec 30, 2010 1:20 pm
hadnt seen that before but that helps alot :D thanks for the info!
i will try to get some pics of it before, during and after the swap.
i cant wait to switch them out, that hitachi POS has been the only problem on my truck that didnt get fixed right away, new engine inside and out. 5k miles on the engine total. but that piece of garbage carb :evil:
"Kit is for off-road use, not for use on highways, or in california" thats exactly the kind of parts i want on my truck mo powaaaa :lol: gotta love power parts
PostPosted: Fri Dec 31, 2010 2:41 am
Now all you need is an Offy intake! :D I still have plenty, so let me know if you are interested.
http://www.purerockradio.net/
PostPosted: Fri Dec 31, 2010 9:49 pm
lol. one of these days if i can afford it. i need headers too.
anyone have a rocommendation for what type of gasket sealer to use on the bottom gasket?? it says dont use RTV so im not sure what would be best
PostPosted: Sun Jan 02, 2011 12:13 pm
If your referring to the carb gasket, if you look to the end of vid 1, you'll see I use anti-seize. You can use anti-seize, white grease, or Vaseline all work well as both a seal and anti sticking agent. You can install them dry also but they can dry out and also stick together to the carb, adapter or manifold. If you ever need to make changes (like swapping manifolds) it can be a pain when it sticks and rips apart. .
Users browsing this forum: Bing [Bot] and 32 guests
