It is currently Wed Jul 01, 2026 7:17 am
 Post subject: cv joint ?
PostPosted: Tue Nov 16, 2010 5:10 am
Australian LUV Guru
How do i get the shaft out my old outer cv so i can fit it to the new cv? :?
1980 4x4 KBD40 ISUZU/Chev Luv
 Post subject: Re: cv joint ?
PostPosted: Fri Nov 19, 2010 10:36 pm
I don't know. I wanted to get mine apart to put on a new boot. I ended up using a universal boot that is split, and screws together. I'm not sure how well it's going work either. :cry:
PostPosted: Wed Nov 24, 2010 11:21 pm
Clamp the bar in a vise, and knock it off with a brass hammer. The bar has a split ring that holds the outer cup on. Brass works best so as not to scar up the cup, but if you are replacing and it becomes stubborn you can use a 2 lb sledge. Hope this helps.
1981 chevy luv 4x4 .... in need of alot of work!
1980 chevy luv 4x4 .... my favorite
1976 luv 2x4 auto
Hero or Zero! No inbetween!
