It is currently Sun Mar 22, 2026 1:09 pm
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 Post subject: Re: R1 Carbs on G200
PostPosted: Wed Nov 03, 2010 12:05 pm
ok , kinda small pic to look at .. when you get a chance to get pics ( good size ones) of the tops, sides back and bottom and email them to me ctmandu@yahoo.com
PostPosted: Thu Nov 04, 2010 2:43 pm
i think i figured it out cat the bottom ones are for the overflow.. and the rest are suplly
http://www.motoopartslib.com/2010/03/19 ... e-diagram/
PostPosted: Thu Nov 04, 2010 5:04 pm
i have one supply and 4 bowl drains on mine
PostPosted: Thu Nov 04, 2010 9:16 pm
im thinking the other two are for vaccume i put fuel to the supply and the other two and fuel came out of the left intake hole but when i ran it only through the supply the fuel wouldnt circulate do you think i have to turn the engine over for it to work?....pics coming soon they will be on mikuni meets izusu
PostPosted: Thu Nov 04, 2010 9:37 pm
man , i am not sure ... this is why i went with the R1 carbs as plenty of info ,build, specs and how to's . it was the tried and tested way... you may need to find a motorcycle site that knows the carbs you have and then ask them on what goes where and the proses to rebuild them... some carbs you will have to plus certin jets to make work right otheres you just rejet them some need lots of mods to be run on a car motor... again the best have been the R1 carbs... and a few katana bike carb conversions but not nearly as many as the r1 .. i would luv to help more but i havent seen these or had them in my hands to check them out or how they may funtion, so i am just shooting blind ....
PostPosted: Fri Nov 05, 2010 8:52 am
well u were right about the drains that helped alot
PostPosted: Fri Nov 05, 2010 10:43 am
good
PostPosted: Wed Dec 08, 2010 10:26 am
what happened to ctmandu website been tyring to go on there for last 4 days lol.
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Wed Dec 08, 2010 11:35 am
i have it down right now because i can not pay for it...
PostPosted: Mon Dec 27, 2010 2:48 pm
ok so have you started selling any of these? i am thinking of geting this set up lol income tax is coming! wont get much but should be enough for this set up get back at me man thanks.
PostPosted: Mon Dec 27, 2010 3:31 pm
haven't sold any yet but have a few guys in Australia that want it after the first of the year... pm sent
PostPosted: Mon Dec 27, 2010 3:44 pm
also what would be a better set up on my 1980 chevy luv 4x4.....
my luv has:
1.8l motor bored 30 over head shaved 20 thousands has been rebuilt will be puting 2 inch body lift with 30/9.50/15 tires and the truck has the 4 speed tranny in it.
should i put the r1 carb set up or should i put the offy intake with a weber car? out of these 2 set ups which will get me more hp, fuel milage, and do better off road? the 30 inch tires are not huge but are bigger than the normal size tires the luv usually has....thanks for the info
PostPosted: Mon Dec 27, 2010 4:06 pm
the 32/36 might give better MPG but the R1 definitely more power and is great for 4x4 trucks... the carbs can almost be upside down and not leak , they where made to be at extreme angles and keep constant fuel pressure... i have seen them mounted
straight out like this
and like this. how many carbs you know can do that
PostPosted: Mon Dec 27, 2010 7:55 pm
alright pretty impressive 8O
if only i didnt already have a new weber on the way to my door :econfused
PostPosted: Mon Dec 27, 2010 9:12 pm
well i am almost for sure i am geting this lol because a new carb is $300 easy and the intake is $300 and i can get more hp from this set up and it looks cooler tbh lmfao....anyways i think everyone should think about geting this go to youtube look at the vids of these carbs on the luv its so sick..! :esurprised
PostPosted: Wed Dec 29, 2010 6:43 pm
did you ever get your website back up? i cant remeber what the name was rofl....
PostPosted: Wed Dec 29, 2010 9:11 pm
no ... it is down for good as the shop will be gone and done by the 1st... will try to regroup and maybe try again this summer
PostPosted: Wed Dec 29, 2010 11:51 pm
aw man that sucks.
hold on to whatever parts you can for later on... or throw them up on ebay
PostPosted: Thu Dec 30, 2010 8:17 pm
i might have a guy that will take them all in southern oregon...
PostPosted: Fri Dec 31, 2010 5:15 pm
wait ur luv shop? ur gona be done with luvs??????????????
