It is currently Thu Jun 25, 2026 2:17 am
Post new topic Reply to topic  [ 167 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Thu Apr 01, 2010 7:43 am
eln1972luv wrote:
Everyone please note that the small block fits just fine with exhaust manifolds. I know people are in love with headers but for all except out and out racing, I think manifolds work just fine and as you can see they fit.
yes and no. that style yes. i went ahead and bought a set of used block hugger headers from a member here. couldnt pass up the deal. the style manifold that came on the 305 i am using would not fit as its not centered on the motor and exits the rear of the motor.
manifolds on my motor (i googled and took the first picture i saw)
manifolds on the original posters truck
PostPosted: Mon Apr 05, 2010 11:38 am
Enough with the photoshop versions...
This weekend I removed the step bumper and relocated the license plate back to the stock mount. The stock license light was sitting there waiting to be hooked back up. Then I installed the 3" lowering blocks and got it low like a luv should be.
I also picked up a pair of steel wheels off of a Rodeo at the junkyard with some decent 225.75.15's on them. I took them for a cruise and I would guess that the luv would purr at 80mph with them on. It really brought the RPM down on the engine and smoothed eveything out. I swapped back to the 14's after I lowered it for the maximum lowering effect though. The steel wheels have good backspacing and tuck up inside the bed nicely. The tires are a bit taller than I would like to run though.
PostPosted: Tue Apr 06, 2010 8:07 pm
Looking good! I like the rear of a 72 the best with the 4 big round tail lights. Probably because I have one, and because it's sort of reminiscent of a Corvette.
I guess I don't know which exhaust manifolds do fit, but it looks like some variant of the ram's horn style should. Or even the log style i.e. on 80s Chevy pickups.
PostPosted: Wed Apr 07, 2010 5:13 pm
kinda makes me wanna take the back bumper off mine to see how much better it looks. granted i have a 77 but still
PostPosted: Wed Apr 07, 2010 9:30 pm
Do it! it will look great, but you have to be real careful backing up. I couldn't get that rusty old step bumper off quick enough.
The luv has some really great lines and the bumper takes away from it. I am contemplating taking off the front one too, but I want to retain my sleeper look as much as possible.
PostPosted: Thu Apr 08, 2010 12:50 am
I think its a cake walk from here, everything else I want to do is easy stuff.
Here is a photoshop of what I want to do to the truck.
I love it. The photoshop looks good. This one is my version, non photoshop-
PostPosted: Thu Apr 08, 2010 2:30 pm
i too have considered the front. worse case ... i just put it back on, lol
PostPosted: Sun Apr 18, 2010 9:06 pm
I have been polishing for a week now and it has been slow going. The hood is by far the worst but the shine is coming around. Also I picked up the dash cover I had made with no cut outs, just a smooth cover. It looks better that the cracked dash cap that is under it.
PostPosted: Sun Apr 18, 2010 9:18 pm
That is a straight looking LUV. You are a lucky man!
PostPosted: Mon Apr 26, 2010 1:40 pm
Just over 6 weeks and the shine is back. I found a great deal on a Meguiars DA polisher which made it way easier to get the oxidation off of the paint. Now I need to wax it up.
I also discovered when I went to remove the LUV emblems off of the fenders that they are not factory emblems at all. They are solid aluminium castings from a stock emblem and were screwed on from the back. They will polish up pretty good and I may put them back on. I talked to to prior owner and he confirmed that he had made them in high school in a foundry class. I also swapped out the grille emblem and took off the big yellow bowtie for something a little more to scale.
Also picked up a 70 Camaro gas pedal assembly so I can remove the threaded rod throttle linkage and put a cable on it.
Its hard to keep focused on just building a driver to go to Home Depot in when I see all of the awesome builds on this site. The V8 just screws with that whole idea, this thing is so much fun to drive!
PostPosted: Sun May 23, 2010 7:22 pm
Found a 74 Mikado at ecology center and I snagged the stainless from the doors and rain gutter.
[attachment=0]chrome2.jpg[/attachment
PostPosted: Sun May 23, 2010 7:38 pm
lookin good. thats one damn clean truck for its age
PostPosted: Sun May 23, 2010 9:48 pm
You are a lucky man, Luv's in that condition are hard to find. That's one nice ride.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Mon May 24, 2010 11:08 am
Thanks for the kind words guy's. I was a little worried when I first got it because I thought it was pretty rough, but it has really worked out pretty good. I think it has been parked much of its life and doesn't have the wear and tear like most Luvs have. :)
PostPosted: Tue May 25, 2010 4:18 am
i think it needs black stock wheels all round that would se it right off, yes this is a tidy little ride very nice.
PostPosted: Sun Jun 27, 2010 1:33 am
I saw a V8 Luv at the donut shop last weekend and he had an aluminium shroud over the radiator, so I thought I would give it a shot.
PostPosted: Sun Jun 27, 2010 8:47 pm
I spent another day on it today. I replaced the threaded rod with a throttle cable too.
PostPosted: Thu Jul 01, 2010 9:41 pm
I'm starting to dig playing with sheet metal. I finished my first door panel today, then did a quick glove box cover. The speedo will be harder to pull off.
PostPosted: Mon Jul 05, 2010 9:57 pm
I finished up the drivers door panel, then hit the junk yard and scored a set of Accel 8.8 wires for $8 which cleaned up nicely. I'm a sucker for yellow wires. I also found a Mikado with a decent set of blue seat belts and a perfect ashtray with lighter.
PostPosted: Sat Oct 23, 2010 6:07 pm
I picked up some chrome bezels on craigslist and shined them up. The chrome under the paint was in great shape.
