It is currently Thu Jun 25, 2026 8:02 am
 Post subject: Aftermarket coils
PostPosted: Fri Oct 15, 2010 11:43 pm
Guys I need to replace my coil.It is leaking oil and in a coil that is not good. What would you suggest? Also what are the stock coil resistance specs and how hot of a coil can I run with the points?
 Post subject: Re: Aftermarket coils
PostPosted: Sun Oct 17, 2010 2:10 pm
i've heard of people running msd boxes with the stock points. so i'm not sure if any certain coil will kill it.
1980 Chevy Luv 4x4 mikado factory Black.
1.8L 4spd
PostPosted: Sun Oct 17, 2010 4:23 pm
I found the cheapest one I could buy about 15 dollars and bought two. One is still in the box sitting behind the seat. Keeping it company are a water-pump a voltage-reg, an alt. a set of points, dist cap, rotor, condenser and a ballast resistor among other friends.
1980 4x4
PostPosted: Sun Oct 17, 2010 4:48 pm
Some cold, dark night a long way from home, it will pay off. If nothing ever does happen, that is a bigger victory.
PostPosted: Sun Oct 17, 2010 5:36 pm
you sure are prepared. heh. when i bought mine it came with a bunch of spare gaskets, exhaust, intake, head, couple others. spare voltage regulator but no condensor. carb rebuild kit, some tail light lenses... now that i think about it most of mine are still in good shape, i'll inventory what i have and post up what i'm willing to part with in another post. prolly nothing tooo rare...
1.8L 4spd
PostPosted: Sun Oct 17, 2010 5:38 pm
you kidding with these trucks everything is rare lol :lol: :lol:
luv less for the time being
PostPosted: Sun Oct 17, 2010 7:06 pm
Forgot about the fuel pump under the seat. The extra water pump and fuel pump came with the truck. At fifteen dollars a coil is a coil is a coil. I left my ignition on once and my air cleaner housing still has coil blood on it.
1980 4x4
