It is currently Sun Mar 22, 2026 1:09 pm
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: R1 Carbs on G200
PostPosted: Tue Sep 28, 2010 10:46 pm
Thank you Andrew... yes it is all stock but minus the smog equipment and just a aftermarket header... I have a stock pints dizzy on it without the vacuum attached so I am sure if I had that it would of been even better...
Now that I know it works well with a stock setup an will be trying the EDIS and mejajolt system next. the wiring harness is made and ready to go, just need to calibrate the TPS on the carbs and then hook to my laptop and start mine tuning an timing map for it, should give me even more power and toque... nice thing about the megajolt is it is a 2 map system so I can have one for fuel economy and one for just wanting to romp on it, all hp map if you will....
andrew was thinking of doing a weber but i think i have changed his mind...
I can do intake, carbs and throttle cable, carbs cleaned tested and tuned for $599 this will be the luvtruck price. my website price will be $675
PostPosted: Tue Sep 28, 2010 10:52 pm
rainman105 wrote:
Isn't there a way to put a vacuum port on one of the runners on that manifold, CT?
Yes there is. I have a spot in the front runner for it I just didn’t want to open it as I will not be using it on mine...
As you can see on this pic. It is there but not threw the runner. You can finish it to use as a vacuum port or leave it like it is and use it as a mounting point for something else like maybe a wire holder or one for the heater hose, anything like that
PostPosted: Wed Sep 29, 2010 9:55 pm
would a set of 38mm carbs work too?
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
PostPosted: Wed Sep 29, 2010 10:43 pm
dont think so.. this is set up for the r1 and they are the 40mm... the r1 seams to be the carb of choice from the tuners
PostPosted: Thu Sep 30, 2010 9:53 pm
i need to start saving money! and you're in salem which kicks arse
1980 Chevy Luv 4x4 mikado factory Black.
1.8L 4spd
PostPosted: Fri Oct 01, 2010 1:20 am
sounds good...
worked on the megajolt today and hooked up the laptop all seams ok but then my battery went dead... will work on it again when i get time...
PostPosted: Fri Oct 01, 2010 7:24 pm
was able to get the EDIS working , so the luv no longer has a dizzy... all running with the megajolt and EDIS
anyone want an electronic dizzy from a 84 trooper easy to hook up , 1 wire pos 1 wire neg on the coil... works great and never let me down... pm me if interested
PostPosted: Sun Oct 03, 2010 4:08 pm
Got the for EDIS installed and the megajolt... running great just need to do some playing now to get the max out of it...
With the magajolt in I now can tune the timing for max performance or just good old fuel economy if I wanted and anywhere in between
PostPosted: Sun Oct 03, 2010 8:20 pm
cool.. are the carbs fuel injected?
PostPosted: Sun Oct 03, 2010 8:22 pm
:signanyone
PostPosted: Sun Oct 03, 2010 8:56 pm
no, the carbs
are carbs
but R1 FI throttle bodies can be used but you would have to use megasquirt not megajolt....
PostPosted: Mon Oct 04, 2010 1:24 pm
hey could we get a small vid of u driving the truck with the carbs u got on....maybe a little tire smoking :D if not thats cool just interested in how it sounded while driving and how good it breaks the tires lose...lolz :ebiggrin
Chevy luv with a redneck grabber green paint job lol...
these are links to my luvs pics.
http://s922.photobucket.com/albums/ad68 ... v%20truck/
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Mon Oct 04, 2010 3:12 pm
thank you ctmandu. i looked at the pics of the carbs and i was all confused.. :? thay have bolls like a carb but have a tpi like Fuel Injection.
PostPosted: Mon Oct 04, 2010 8:22 pm
that’s why people like these, run them like they are or run them with a standalone computer because of the TPS on them. That will tell the computer what load the engine is under...
PostPosted: Mon Oct 04, 2010 8:23 pm
Andrew and I are trying when we both have the same time to work on it... he is quit busy and I need 2 to do it...
PostPosted: Mon Oct 04, 2010 8:30 pm
Lets do it tomorrow after I get off work. I need a few parts too
PostPosted: Mon Oct 04, 2010 8:34 pm
sounds good. got home late after moving my dad and never made it to the shop... what time do you get done with work tomarrow
PostPosted: Tue Oct 05, 2010 8:36 pm
here you go... still babying it as not sure how good the motor is as i dont know how many miles are on it....
he won the first time as my tires would gust spin.... 2nd try i was wasnt as hard on it so i could get some traction... as you can see in the video i was still spining them as i left the line...
PostPosted: Tue Oct 05, 2010 9:54 pm
rematch! I had a building in the way!
:smt097
j/k You had me
PostPosted: Tue Oct 05, 2010 10:07 pm
fun fun fun... just need better traction....
