It is currently Tue Jun 30, 2026 10:52 pm
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
 Post subject: Re: R1 Carbs on G200
PostPosted: Sun Sep 19, 2010 11:42 am
have seen people do it...
PostPosted: Mon Sep 20, 2010 11:56 am
now THAT setup would sound MEAN coming down the road 8O 8) :ebiggrin
PostPosted: Wed Sep 22, 2010 11:04 pm
Well that's looking mighty good. What year did you get those off of, does any year work, checked on ebay and found a lot of 04-08 stuff, and I think those are all fuel injected right.
1975 luv daily driver.
Project-soon to be revived
PostPosted: Thu Sep 23, 2010 12:08 am
Mine are 99 yamaha r1 but the 98 to early 2001 are the same. Just make sure they are carbs and not TB's
You can use any kind but everyone seems to use the 98/01 R1 as they are the best and easy to convert over... most companies that make the intakes only do so for the R1's
i have seen them on ebay go for under $100 and as much as $200 have seen some on the R1 forums go for $50 so you just have to look around ... allso you can check the bike wrecking yards...
PostPosted: Thu Sep 23, 2010 3:40 am
any idea about the possibility of using the TB setups?
02 and up are the TB but its a simple vacuum setup so it shouldnt be that hard to adapt
Source- http://en.wikipedia.org/wiki/Yamaha_YZF-R1 lol i asked the expert :lol:
PostPosted: Thu Sep 23, 2010 10:53 am
not sure yet. i hope to do that set up next year as the megajolt wont do FI and i would need to get the megasquirt which is about $400
PostPosted: Thu Sep 23, 2010 7:59 pm
you can get the megasquirt assemble yourself system on ebay for $200 if you know how to solder.
PostPosted: Thu Sep 23, 2010 11:20 pm
Yes but I am not a good electronics guy and I figure I would mess it up. As with the megajolt you can buy in kit form for $89 but I went for the assembled one for $160...
my luck i would fry it when i put it together...
PostPosted: Fri Sep 24, 2010 1:23 am
i know the feeling X^D the thing stopping me would be the fear of frying it or bridging something that isnt supposed to be and startin an electrical fire X^D
PostPosted: Fri Sep 24, 2010 6:39 pm
Well finally put the air cleaners on... here you go...
Next I am working on the edis, should be ready to fire up soon...working on this and fiberglass so I dont get to spend allot of time on it...
PostPosted: Fri Sep 24, 2010 10:08 pm
Sweet looking set up...
PostPosted: Sat Sep 25, 2010 4:47 pm
NICE!!!!!!!!!!! 8)
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
PostPosted: Sat Sep 25, 2010 6:48 pm
thank you
PostPosted: Sun Sep 26, 2010 10:08 pm
ctmandu wrote:
well i had to pull the motor as when i pulled the head off to check the valves i found this...
so i need not just fix the timing chain but....
how does that happen??...i bought a quad carb im puting on my 77...
PostPosted: Sun Sep 26, 2010 10:35 pm
i was told my timing was off...
PostPosted: Mon Sep 27, 2010 8:29 am
so it was the valve?....how did the hole get there
PostPosted: Mon Sep 27, 2010 10:32 am
th timing was to advanced and the the pressure and heat caused by the gas exploding to soon burnt it... i was told but it doesn't 100 % make since to me because it is only on one not all four...
PostPosted: Tue Sep 28, 2010 6:48 pm
yea thats a bit confusing? unless you had a bent valve in that cylinder along with the off timing?
PostPosted: Tue Sep 28, 2010 8:58 pm
Stopped by ctmandu's shop on the way home today and he took me for a spin around the block. I have to admit even untuned with the stock ignition system and no vacuum advance that g180 pushed my back into my seat.
It was a depressing ride home in my stock truck. :smt088
Good work ct sign me up for version 2.0.
PostPosted: Tue Sep 28, 2010 10:35 pm
Isn't there a way to put a vacuum port on one of the runners on that manifold, CT?
