It is currently Wed Jul 02, 2025 12:55 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Sep 11, 2010 10:30 pm
ok bought this luv for 200 bucks.
had to put a fuel pump on it to get it home.
its a 1980 luv mikado 2wd w auto.and a/c
it will be getting the customary SBC swap.some minor body mods like removing the side markers and relocating fuel filler. different wheels for ease of finding tires and what ever else i come up with in the process.
luv less for the time being
 Post subject: Re: my luv done my way
PostPosted: Sat Sep 11, 2010 10:35 pm
spent a little time working on it today. did rear brakes, put a fuel pressure regulator on it because i installed the wrong fuel pump and the regulator was free, and took 3 cans of flat black to it and got rid of as much of the gold spray paint on it as i could. also orderd a kit for the stock carb.
my friend hooked my up with a complete mid 80's caprice for a donor car but i won't have the money to pay him till end of the month so for now i'm just getting it road worthy so i can drive it to college on rainy days. on sunny days i get to ride my other baby 8)
camera needs batteries i'll get picks of the no gold tomorrow.
PostPosted: Sun Sep 12, 2010 6:05 pm
no more gold
PostPosted: Sun Sep 12, 2010 10:19 pm
Looks much better, are you going to hit the wheels too? I'd just paint the red part.
PostPosted: Sun Sep 12, 2010 10:38 pm
Looks way better with black grille and headlight bezels
PostPosted: Sun Sep 12, 2010 10:45 pm
the wheels aren't staying so i'm not going to waste my time on them. if i was going to use them i would definitely shoot the red black :lol:
PostPosted: Sun Sep 12, 2010 10:47 pm
top rail around the bed and around the door glass too. looks a lot less ghetto.
PostPosted: Mon Sep 13, 2010 6:31 am
To bad your not closer or I would get them from you. I like those old turbine style wheels.
1990 Chevy Suburban
PostPosted: Mon Sep 13, 2010 12:22 pm
i like the wheels too but they are 14s and i'd rather have 15 or 16s. when i get some different wheels the turbines are going on my older brothers 1985 d50
PostPosted: Mon Sep 13, 2010 1:06 pm
I have a luv almost identical to your besides the long bed and color.
I found a cheap set of headers for mine. gave it it a little bit more kick out of that 4-banger, also upped my gas mileage.
If your interested let me know and ill point you to the site.
TUFFLUV
PostPosted: Fri Sep 17, 2010 9:13 pm
payed for my donor today. 1983 caprice classic with 66,000 actual miles. other than the radio missing and a slight sun fade on the top of the fenders car is pristine. won't be for long :lol: :lol:
5.0 700r setup.
i'm going to try to use the 700 but if i can't work i out i'm sure i can trade it off for a t350
PostPosted: Sun Sep 19, 2010 6:18 pm
motor in donor has thrown a rod, # 4 or 6. have a dime sized hole and the oil pan is dented out wards on the pass side above the cross member. working on getting engine out to see if block is cracked or not. working out a deal with another friend to get a 305 hes had for awhile for bottom end parts and spare block. :roll:
PostPosted: Tue Sep 21, 2010 5:59 pm
some positive news:got tags and insurance on truck yesterday and actually drove it to college and back today with out breaking down :lol:
PostPosted: Tue Sep 21, 2010 11:27 pm
I have a 5.0 and a 700r4 in mine. Should be up and running a couple days. 700 is pretty much the same as a th350 but it has over drive. Why wouldn't you be able to use it?
PostPosted: Tue Sep 21, 2010 11:44 pm
yeah i posted that before i did a little site searching. i will be using the 700r4. it actually might be the only thing i can use off the donor car. :lol: i'll find out for sure this weekend once i get the engine out and see how much damage the thrown rod did.
PostPosted: Thu Sep 23, 2010 5:37 pm
pulled the grill and all the under hood a/c components today.
PostPosted: Sat Oct 02, 2010 11:17 pm
alt off donor installed on 1.8
also pulled tranny from donor.
was going to trade 700 to a friend for 305 long block and t350 but turns out t350 has busted bellhousing and his 305 longblock is MIA.but atleast he helped me pull the tranny
been an interesting week.
PostPosted: Sun Oct 03, 2010 5:59 pm
pulled and disassembled engine from donor today.
#6 rod came undone took a 2x2 chunk out of the cylinder and beat the crap outta the crank. so i need a short block now
PostPosted: Thu Oct 07, 2010 6:18 pm
ok i have had some fun with this engine thing. bought the car engine no good traded tranny for busted tranny and missing motor. got tranny back and was supposed to get 350 short block last night. they never showed up. i'm headed 2 towns over tomorrow night to buy a 350 4 bolt for 100 bucks wish me luck :lol: :lol: :lol:
PostPosted: Sat Oct 09, 2010 6:10 pm
picked up engine last night and tore it down this morning.
4 bolt 350 out of 1980 4x4 c1500 some yahoos had stuck 400 rods with 350 crank and smacked a piston.
462624 heads on it will go in scrap metal pile. have a set of 416's to use.
will have to have block bored due to cylinder rust in #4 and ring groove at top of cylinder.also needs new cam bearings.
also picked up a 4165 Holley 650cfm dp spread bore
