It is currently Fri Jul 18, 2025 11:33 am
 Post subject: Tie rod conversion
PostPosted: Wed Sep 15, 2010 10:10 am
Well I needed new tie rods for my truck and called moog and they no longer manufacture or carry tie rods for the luv. So I started checking out some tie rods from different vehicles for same length and taper. I found out that 68 through 74 chevy nova tie rods work perfect.
Inner is a moog#es681n
Adjusting sleeve #es350s
Outer#es381r
 Post subject: Re: Tie rod conversion
PostPosted: Wed Sep 15, 2010 1:30 pm
Awesome!
I was planning on doing this soon but using heim joints. But this is way better for a driver in dusty AZ.
1975 Project LUV
It's ALIVE!
PostPosted: Wed Sep 15, 2010 2:07 pm
i was also gonna use heims but the holes in the spindles, and the holes in the ideler arm and pitman arm are already larger than 1/2 inch and i only had 5/8 heims with a 1/2inch hole so it wasnt gonna work
PostPosted: Wed Sep 15, 2010 2:53 pm
Outer#es381r
Good work, thanks for sharing.
PostPosted: Wed Sep 15, 2010 3:56 pm
its also nice being able to adjust the tie rods and not the stupid center link. my center link was siezed up and i made a new one with heim joints and tube
PostPosted: Wed Sep 15, 2010 4:03 pm
if i plan ahead and use heim joints (getting the right size and such).. is that better than using stock replacement type stuff?
PostPosted: Wed Sep 15, 2010 5:09 pm
most race cars use heim joints for steering. it is fine. you just gotta drill out the taper in the holes and you wanna make sure the bolt fits snug and use lock nuts and if you use it on the spindle i would put a 1/2 spacer between the heim and spindle to allow for more travel (articulation) if bagged.
Users browsing this forum: Bing [Bot], Google [Bot] and 22 guests
