It is currently Sun Dec 14, 2025 1:44 pm
Post new topic Reply to topic  [ 141 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Sat Sep 11, 2010 10:21 pm
Hi my name is chris, I live in lytle texas, I bought this truck in april. I paid $250 for it, then paid $50 to get it towed to my house, once it was at my house i did some tinkering on it, changing points,coil,ect........
PLease post What you think,what i should do, what i should have done, any info is good!!! thanks so much
Anyways once i got the truck started it was knocking really bad, and smoking white smoke like crazy.
So i removed the head and i found 3 bent valves, took it to the machine shop.
The head was warped so it got shaved 20 thousands, piston had scratched the block so that got bored 30 over.
This is a list of things i bought/paid for.
Item-----------------------Cost-----------------------From
Head and block work $360
Matching piston set $100
Re-ring kit $186.98 shiped Northernautoparts.com
Fuel pump $50.00 Napa
Coil $21.99 OReillyAuto
Point set $2.99 OReillyAuto
Water pump $24.99 with $5.00 core Autozone
Oil pump $50.99 Autozone
Timing set $55.99 Autozone
Air filter $5.99 Oreillyauto
Thermostat $5.99 Oreillyauto
Puting motor together $150.00 Richardsautomotive
Items needed---------------------Will be geting all this soon :ebiggrin
Oil
Oil filter
Battery
Tires
Body lift
Header
Weber carb
Dual plane intake
Cherry bomb/glass pack
Snorkel hopfully
Locker for rear (If there is one made for the luv). :)
Paint
Now there is prob alot of stuff i have left out....but it is all good i will update it lol.....
Check out all my pics now and please remeber that my other page messed up all my pictures are ruined, I do not know how it happened but this will allow me to show you everything alot better anyways! THANKS :!:
Chevy luv with a redneck grabber green paint job lol...
these are links to my luvs pics.
http://s922.photobucket.com/albums/ad68 ... v%20truck/
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
Last edited by chrisquested on Sat Sep 11, 2010 10:58 pm, edited 7 times in total.
PostPosted: Sat Sep 11, 2010 10:30 pm
Ok here are some pictures of the luv when i 1st got it!
Side view
Front view
The bed
Engine bay (After i presure washed it)
A picture of the inside
The frame all saded down
The frame under coated
Another side shot
The gas tank cleaned inside and out
The tail gate sprayed with duplicolor bed liner
Another picture of the gas tank
Here is another shot of the interior
Another shot of the frame
PostPosted: Sat Sep 11, 2010 10:34 pm
Now here are some before and after pictures.
Engine bay before
Engine bay after
Side view before
Side shot after
I got alot more pics!
PostPosted: Sat Sep 11, 2010 10:36 pm
Ok here is all the sanding/priming/painting!!!! :twisted:
Here is a pic with no fenders!
Here is the hood lol!
PostPosted: Sat Sep 11, 2010 10:39 pm
looks like you have done a crapload of work. well done sir
PostPosted: Sat Sep 11, 2010 10:40 pm
Now here is some engine pics
Intake
Engine before it went to the shop!
Oil pan
Valve cover
Pistons
Head
Block
PostPosted: Sat Sep 11, 2010 10:42 pm
Alrighty here is what i have done with the interior!!!!! :D
Old pic of interior!
PostPosted: Sat Sep 11, 2010 10:45 pm
Now this is what i have done as far as painting!
The grill
PostPosted: Sat Sep 11, 2010 10:47 pm
Look at this little luv truck is is turning into somthing cool now..... :gayfight
PostPosted: Sat Sep 11, 2010 11:04 pm
I think that i might end up taking my rims off sanding them down and painting them gloss black..... :wink:
PostPosted: Mon Sep 13, 2010 5:01 pm
here are some more pictures!!!!!! :twisted:
The motor should be put together and hopefully put in next week some time.....my re-ring kit should be here today or tomarrow...then it should not take my mechanic to long to put it together.....
PostPosted: Mon Sep 13, 2010 5:37 pm
what is my "arrow" pointing to? i dont know what this part is and whats under it
PostPosted: Mon Sep 13, 2010 6:43 pm
It is just a cover and on the inside is i think 2 relays of some kind....wires going into 2 small gold boxes....so wierd.......but it looks cool painted green lmao.... :lol:
PostPosted: Tue Sep 14, 2010 1:54 am
its the flux capacitor. it makes the truck go back in time. :lol: :lol: :lol:
no you got it right .. 1 is the head light relay and the other is fuel pump relay.
PostPosted: Tue Sep 14, 2010 6:31 am
Not into green, but looks good. Cool pics. Keep up the pics.
PostPosted: Tue Sep 14, 2010 7:44 am
That is my favorite color that LUV's had. I think it is called shannon green? Are you rattle can painting it? When you paint the dash tray you may want to use the Duplicolor bedliner spray that you used on your tailgate. I used it on mine and I am very pleased with it.
PostPosted: Tue Sep 14, 2010 9:33 am
truck is looking good! keep up the good work and speedy pace. i would paint the wheels with the bedliner spray.
PostPosted: Tue Sep 14, 2010 9:40 am
the luv came in green? i dont think ive ever seen one. just blue, yellow, red, white (thats all i recall seeing just off the top of my head). interesting.
PostPosted: Tue Sep 14, 2010 2:20 pm
They did come in green but mine was blue when i got it and i sanded it down the i primed it washed it the painted it with grabber green engine enamel once it dryed i gave it about 2 coats then i shot a clear coat over it....i think it look good for a rattle can job...... :lol: anyways thanks so much for the comments keep on with them i like to hear good and or bad feed back and if you have any idea that you think i should do let me know i will condsider it.
Idea i had before was to take the cab and bed off this frame throw it onto a s10 frame/toyota fram and put 12 inch of lift 36/15.50/16 tires on it with a chevy 377 stroker.....but then that got thrown out when i found out my gf was having a baby
the [aint job was gona be duke of hazard style also lmao!!! would have been sick.....anyways thanks again!!!!
PostPosted: Tue Sep 14, 2010 3:06 pm
Nice!
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
