It is currently Wed Mar 18, 2026 2:57 pm
PostPosted: Wed Sep 08, 2010 12:37 am
https://www.northernautoparts.com/Produ ... Id=1338136
i am planing on ordering this kit off of northernautoparts.com the thing is i got my motor bored out 30 over or 75mm and i need to get my piston rings so does that mean i get them 75mm also??????????and is this a good kit?
It comes with sealed power piston rings and victor stock style gasket set? and with this kit can i put my whole motor back together?
Sealed Power stock style Piston Rings
Federal Mogul stock style Rod Bearings
Federal Mogul stock style Main Bearings
Federal Mogul stock style Thrust Washer Bearings
Victor stock style Gasket Set
this is how my motor sits right now block crank head piston set......
So i need to know what else i might need to order i got to put my whole motor back together i will order this kit!!!!
then i got a oil pump, water pump, timing set, and clutch set. is that alll!??!?!?!??!?!?!?!? :?: :?
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Wed Sep 08, 2010 7:13 am
yes your rings need to match your pistons
luv less for the time being
PostPosted: Wed Sep 08, 2010 9:47 am
And ring gap needs to be checked, so you can be sure you have the proper end gap...
PostPosted: Thu Sep 09, 2010 4:07 pm
Well i ordered it alll today and this is how i filled out my order.
Chevy 1.8L Luv Pickup 1976-1982 - Rering Kit
Price:
$163.99
View Optional Components Chevy 1.8L Luv Pickup 1976-1982 Re-Ring Kit
Includes:
Please note… Occasionally we will substitute top quality brand names in our engine kits. Some examples are Melling & Sealed Power, Perfect Circle & Hastings, Clevite & Federal Mogul. Thank You.
Make:
Chevy
Model:
Luv
Year:
76-82
Category:
General Motors
Brand:
Engine Kits
Part Number:
ER0632
Required Options:
*Main Brgs:
std
*Rings:
.75mm
*Rod Brgs:
std
PostPosted: Thu Sep 09, 2010 4:09 pm
i dont know wat end gap is or ring gap is wat i ordered corect?
PostPosted: Thu Sep 09, 2010 4:37 pm
you ordered the right parts and here is a link to checking end gap
http://www.aa1car.com/library/ring_end_gap.htm
PostPosted: Thu Sep 09, 2010 6:17 pm
thank you so much guys you were such a great help i cant wait till they get here so i can get it put together!!!!!!!!! :) :D
PostPosted: Mon Sep 13, 2010 1:16 pm
Ok now i finaly scraped up just enough money to pay this guy to put my motor together.......
Everyone says the luv 1.8l motor is underpowered from factory.....HOW DO WE CHANGE THIS?
A carb? Header? Exhaust? Intake? Coil?
I need to know what i need to buy now......
I GOT:
Re-ring kit
Water pump
Oil pump
Timing set
Coil
Point set
Battery terminals
I read in a thread some where on this site about a guy who adjusted his valves and got better fuel millage and more power?
How do i do this? will it make my truck run better? these trucks are extremly slugish? They run at really high rpms? will they cruise at 70 mph without blowing a motor?
Is there a certain way i can do this stuff so my truck gets 30mph,has some power,is able to run lower rpms?
WITHOUt major swaps?
I am going to be using this truck as a daily driver, to my parents, to work, to the store, ect......but also when it rains i will take it in the mud....not hauling A$# or really raging it out but cruising through the mud....driving in some water abou 2 feet not extremly deep.....and climbing some hills here and there not seriouse trail rides...and maybe going to the coast and driving down the 4x4 only beach......
PostPosted: Mon Sep 13, 2010 1:22 pm
If i want a webber carb will it bolt right up to the stock intake? and if i buy a dual port intake from moka will it bolt right up to that? which one should i get? i live in texas san antonio area and you know what i plan on doing in my truck so just let me know exactly which one.
i know there is electric and manual or w/e but i dont know about carbs.......
With the carb, intake, header,and exhaust it says that adds 25 hp is that a big increase can you feel it?
will my motor being bored 30 over and the head shaved 20 thousands adding the carb, header, intake, exhaust, how much hp will i then be at?
I dont know if it matters but i will be later adding 2 inch body lift, t bar crank, and some LT225/85R14 tsl radials The tires are 28.7/8.80/14r ..........
