It is currently Fri Aug 08, 2025 1:49 pm
Post new topic Reply to topic  [ 80 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Aug 21, 2010 5:33 pm
Any vehicle with nuts on it should be crushed! :econfused
PostPosted: Sat Aug 21, 2010 8:10 pm
To answer your question about the horn looking deals on the intake... that is twin carbs... look under ctmandu pics of his truck and he ran something similiar... I believe they were delarato carbs
PostPosted: Fri Aug 27, 2010 2:38 pm
wow thats pretty cool and about the nuts i dont like them neither but i would like to have a bed like that lolz....
Chevy luv with a redneck grabber green paint job lol...
these are links to my luvs pics.
http://s922.photobucket.com/albums/ad68 ... v%20truck/
viewtopic.php?f=33&t=22598
:usa :minigun: :bio:
PostPosted: Wed Sep 01, 2010 2:41 pm
Here is a picture of the engine bay now i sprayed engine degreaser and i will be washing it out then painting it black.
Here is a picture of the grill after i painted it.
PostPosted: Wed Sep 01, 2010 3:50 pm
This is what i did with the door panels!!!
before ( not that good of a pic of the door panel but u get the point)
And after!!!
PostPosted: Wed Sep 01, 2010 3:52 pm
This is the intake painted!
This is a pic of what i did to the oil pan and the valve cover.
What do you guys think!!!!!!!!!!!
WHat do yall think!!!!!!!!!!!!
PostPosted: Wed Sep 01, 2010 5:56 pm
buddy in highschool had a 59 3/4 ton chevy long bed. sprayed the entire truck flat black and then did just the grill antifreeze green. swear to god it looked like it glowed in the dark
luv less for the time being
PostPosted: Wed Sep 01, 2010 6:45 pm
i really like the way it is turning out i am at this point scraping the dang dash to get that yellow glue and foam stuff off so i can spray it and make it look a little nicer lmao....then i think ima pull the seat out and spray the entire floor and behind the seat with a bed liner.....anyways i am going to figure out what to do for sound system....this thing came stock with 1 speaker mounted in the dash and the radio that came with this truck was am only lmao so i got no clue on wat ima do about get speaker and stufffffffffff......................i will prob get a piece of wood build a little box for some small speaker and 1 12 inch shallow mount sub and put that behind my seat......i got a 800 watt exile shallow mount sub in a truck kicker box already.....
PostPosted: Wed Sep 01, 2010 8:16 pm
Progress looks awesome. You're on the way.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Wed Sep 01, 2010 9:36 pm
Just an FYI, your arm rest is on the wrong door. :esurprised
PostPosted: Thu Sep 02, 2010 10:55 am
AHHHH omfg it is lmao wow i got to go change that right now :oops: :oops: hmmmmmm i knew that it didnt look right it didnt even pull the door panel tight either there is like a little space still in between the door panel and arm rest maybe thats why...... :esad
PostPosted: Thu Sep 02, 2010 10:57 am
should i paint my window crank green also?? i am going to go work on geting the dash cleaned and the sprayed......
PostPosted: Thu Sep 02, 2010 6:30 pm
Took my gages out today to clean and paint dash and i ended up doing this lol......
PostPosted: Thu Sep 02, 2010 6:57 pm
ok here is a pic of the gage cluster back in the truck! and also had to keep on cleaning and ended up doing the vents shift nobs and glove box........ check them out
this is the door panel i switched the arm rest back around like it should be.....
THESE ARE THE FEFORE PICTURES BTW~!!!!!
The next thing i will be cleaning the floor boards and spraying them down with rustoleum bed liner in a can just to make them look half way decent.
PostPosted: Thu Sep 02, 2010 9:40 pm
You're making progress. Man that green is off the chart. It's going to make things POP!
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Fri Sep 03, 2010 7:28 pm
yea i think once the bench seat gets pulled i will take it and get it redone black with a green chevy symbol, or get black/green racing seats, but i got to get that sucker out of there so i can finish cleaning/sanding the floors and get them sprayed with that bed liner or just black lol then i will paint the whole truck green with big 4x4 on the hood in black and tint the windows also......and that is about it right now......i just sold my 5000 watt critical mass 12 inch ul seriese sub woofer for $550 and 2 12 inch jl audio w6v2 subs now i got to sell those jl and buy alllll the parts to redo my motor/trans w00t w00t lmao......!!!!!!!!!!!!!!!!!!!!!!!!!!!!!yes sir this is so sick....
PostPosted: Sat Sep 04, 2010 8:21 am
The one we just finished was my sons truck, my '79 is still waiting, we got started on it a while back and life got in the way, then when my son bought his...naturally that took priority. Now I need to get back on mine. You've got me thinking about a different color scheme but don't worry I won't steal your green idea. lol. I've been pondering the idea of a white base coat with an Atomic Orange top coat and a little black thrown in the mix. I think your truck is going to grab some attention for sure. Keep going and definitely keep us posted.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Sun Sep 05, 2010 4:34 pm
yea i was going to go with an artic white with some gloss black thrown in and some hugger orange lol.....but this green kept geting me so ima do it green i like it alot!
PostPosted: Sun Sep 05, 2010 7:53 pm
Ok guys this is what is new so far! I pulled the hood off and sanded it down and pulled 1 fender off then it got dark.....so i am hoping to get the hood and the whole front clip sanded/painted with primer......thats it for right now.
PostPosted: Sun Sep 05, 2010 8:06 pm
That's alot of progress. Keep at it, you will eventually get it all done and be cruising around in your LUV.
1981 Luv 2WD
1981 Luv parts trk
