It is currently Wed Jul 01, 2026 12:04 am
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 9  Next
 Post subject: Re: R1 Carbs on G200
PostPosted: Fri Aug 20, 2010 8:00 pm
hey... how is this swap coming along ctman?
PostPosted: Fri Aug 20, 2010 8:58 pm
truck is at the shop now and will start next week or two on it....
PostPosted: Fri Aug 20, 2010 9:25 pm
well I look forward to seeing the final product indeed
PostPosted: Fri Aug 20, 2010 9:41 pm
saw a set of r1 carbs on ebay for buy it now of $25 if any one wanted to know
PostPosted: Sat Aug 21, 2010 11:28 am
so I was at the cruise in thursday night and saw a vw with a 8valve motor with r1 carbs on it as well but he was still using a distributor.... is this possible to do on a luv?
PostPosted: Sun Aug 22, 2010 12:35 am
Yes... that will be the way I do my first test and tune , all stock but the carbs... then I will replace the dizzy and use the computer to tune to see how much better it is... but yes you can use the stock dizzy an electronic one or even the msd type if you wanted...
PostPosted: Sun Aug 22, 2010 10:17 am
oh man... now you have got ideas stirred up lol
PostPosted: Fri Aug 27, 2010 11:35 pm
well i had to pull the motor as when i pulled the head off to check the valves i found this...
so i need not just fix the timing chain but....
PostPosted: Sat Aug 28, 2010 2:03 am
man, torching a piston is never fun. :(
luv less for the time being
PostPosted: Sat Aug 28, 2010 6:31 am
Goodness what caused that?
James Bates
PostPosted: Sat Aug 28, 2010 9:06 am
detonation/pinging/pinking
PostPosted: Sat Aug 28, 2010 10:25 am
Cat
What about having a custom forged pistons made with valve reliefs?A little more clearance at the valves with give you a little more room for cylinder quench.Make sure to have a plateau finish for the newer rings!
Also what about a gear drive for the timing set?It will handle more rpms and handle more stress load?
By the way the little bugger sounds like a sewing machine on steroids!
PostPosted: Sat Aug 28, 2010 11:26 am
not sure about that or where to get the pistons done... as for the gear drive i not sure as it would take probably 4 gears to work its way down the narrow passage ...
PostPosted: Mon Sep 06, 2010 8:58 pm
Ok got the motor back in from the opel into the luv... same G180 as the luv... any way here are a few pics ....
This is the sensor for the timing. Will not use it at first as i want to run the carbs without the mega jolt then will work on geting the computer in it......
PostPosted: Mon Sep 06, 2010 11:13 pm
That is so cool, good luck with it.
PostPosted: Wed Sep 08, 2010 7:50 pm
good new and bad... it starts and runs but the carbs leak like a son of a gun... will check floats and seals next week and try to keep it updated here
PostPosted: Fri Sep 10, 2010 9:11 pm
well fixed the leaks , the float seat where dirty still... now just need to get some 175 main jets and test it out some more then make the air filter box or may go with individual filters just not sure yet...
PostPosted: Fri Sep 10, 2010 11:29 pm
I vote individual for the coolness factor...
PostPosted: Sat Sep 11, 2010 12:43 am
kinda my thought also and it would be faster then building one....
PostPosted: Sun Sep 12, 2010 3:59 pm
agreed
and individual filters would be simple to find, relatively cheap and go with the look of the engine.
4 carb, 4 header tubes, 4 air filters its all individually setup go with the flow 8) then if u have any kind of problem it will be simple to findout which cylinder is giving you issues. :lol:
im thinking i may have to get myself a setup like this. mine isnt working out to well for me... i hate that stock carb :evil:
