It is currently Mon May 25, 2026 4:08 pm
 Post subject: Chevy Luv Frame
PostPosted: Fri Aug 27, 2010 5:20 pm
I want to length the frame on a chevy luv, does anyone have any Ideas, I was going to cut the frame about two feet back from the front end suspention shock mount , and add about 8" to it I have a chevy lov frame with a model t body, I sure could use some help .. thanks
 Post subject: Re: Chevy Luv Frame
PostPosted: Fri Aug 27, 2010 7:36 pm
http://www.luvtruck.com/PDF/LUV_Demension.pdf
PostPosted: Fri Aug 27, 2010 11:37 pm
I have never fabbed up any frame work but having seen so many people back half thier frames, it seems that the process would be very similar. You would have to ensure you keep your frame square, that every joint was as strong as the original frame. Perhaps if you contacted some of the folks who have baged of back halfed thier trucks they could give you some pointers.
