It is currently Sun Jun 07, 2026 6:41 pm
PostPosted: Wed Oct 08, 2003 4:07 pm
Allright guys here it is I have three questions for you.
1. Does anyone know of a Kit you can buy to change my 78 luv into a 12 volt system and is it really worth it?
2. Does anyone know of a Overdrive kit that can be put onto the tranny because at 60mph my luv becomes a large Gas Hog!
3. About every other time I turn off my luv about 20 seconds after it has stopped running it will backfire? Is my thermostat letting the engine run to hot? I put a gauge set on my luv and everything is in spec? What is it?
thanks for the help.
PostPosted: Wed Oct 08, 2003 6:26 pm
should be 12v system.... :?
PostPosted: Thu Oct 09, 2003 4:53 am
it is a 12 volt system.
a higher ratio rear end would be more cost effective.
check your timing. do a tune up. :D
hope this helps.
03Cobra
PostPosted: Sat Oct 11, 2003 12:29 pm
it should be a 12volt system. About the back firing i agree whith luvforme. ANd you should be able to find something like 3.73 gears out of a luv or early isuzu diesel pick up.
PostPosted: Sun Oct 12, 2003 2:32 am
The backfire problem could be caused by the emissions controls. I had the same problem with the stock motor (1975) and i thought it was the mixture control valve. It went away when i rebuilt the stock motor and eliminated the emissions system all together. Check for air leaks throughout your entire engine just to make sure.
PostPosted: Sun Oct 12, 2003 2:05 pm
blue meanie is right. as soon as i took all the smopg off my truck i tried forever to get my truck to backfire and it wouldn't :D
PostPosted: Sun Oct 12, 2003 7:10 pm
You can also find a rear end out of an s10 with 3.73 gears with little effort. It bolts right in and all you would have to do is get a new driveshaft fabbed.
PostPosted: Mon Oct 13, 2003 10:09 am
the reason why its backfiring like that is because you have low backpressure in your exhaust.
Currently no more luv's... But in search of one!
Users browsing this forum: Bing [Bot] and 64 guests
