It is currently Mon Jun 08, 2026 2:47 am
 Post subject: radiator
PostPosted: Wed Jul 14, 2010 10:32 pm
i have a bad radiator and am thinking of replacing it or rodding it. i was woundering if there was a place to get cheaper radiators (around 150 ish) or if there are other radiators that fit well in the stock mounting place. any help would be appreciated :signanyone
I Dont Need Sex Life Fucks Me Whenever It Can.
 Post subject: Re: radiator
PostPosted: Wed Jul 14, 2010 10:41 pm
People are having more and more trouble finding new ones anymore. Best bet might be a new core installed on your tanks at a rad shop. You can have them make it a 4 row that way too. This is what I did.
PostPosted: Thu Jul 15, 2010 12:39 am
Try Northern Radiator. If not you can have one custom aluminum one made by Griffin or one of the old radiator manufacturers. But the easy one will be to take it to a reputable radiator shop and have them re core it. Get more cores if possible.It will help engine cooling,which helps fuel mileage and longevity of your motor!
PostPosted: Thu Jul 15, 2010 4:47 pm
I am in the same situation, looking for a radiator. Rondog I am pretty sure you posted it before but how much did it cost for a recore? If you dont mind me asking. Im waiting as I speak so to say for a call from napa on whether or not they can get one.180.00 bucks, 50.00 dollar gift certificate from the mother in law will help. Ive tried auto-parts warehouse 122.00 no luck outlaw radiator says it will be 190.00, waiting on napa if no luck I will try them.
1980 4x4
PostPosted: Thu Jul 15, 2010 4:57 pm
I thought about putting a tee in my hot heater hose and the return line and mounting another heater core, or buying a transmission or oil cooler and using it for supplemental engine cooling would any of these things work or are they just ridiculous thoughts of the desperate?
1980 4x4
PostPosted: Thu Jul 15, 2010 6:18 pm
It cost me $60 to get mine rodded out at a radiator shop. Only took a couple of hours, too.
-Micah
05 GTO 6.0
85 Yamaha RZ350
PostPosted: Thu Jul 15, 2010 7:17 pm
did u get it cleaned too? like boiled and stuff?
PostPosted: Thu Jul 15, 2010 8:13 pm
That's what rodding means. They remove the tanks, run small rods through the core tubes, and clean out all the gunk, then put the tanks back on.
I don't recall what I paid for my re core. I think around $200.
PostPosted: Thu Jul 15, 2010 10:12 pm
I took mine to a radiator shop a couple of months ago the guy told me it had good flow and only needed boiling out. Took three days. Not again How hard can it be to braze and poke skinny wire through tubes? We'll see.
1980 4x4
PostPosted: Thu Jul 15, 2010 11:39 pm
well i been w/o my LUV for 2 weeks now so 3 days dont sound too bad lol
PostPosted: Thu Jul 15, 2010 11:46 pm
http://cgi.ebay.com/ebaymotors/1973-197 ... ccessories
PostPosted: Fri Jul 16, 2010 12:39 am
will it fit a 78???
PostPosted: Fri Jul 16, 2010 7:43 am
Try 1-800-radiator I picked one up for $136.00 shipped to my front door. Item number 643VI for my 1977 LUV.
David
PostPosted: Sat Jul 17, 2010 10:03 pm
As far as I can tell, '76-82 use the same radiator. '75 and earlier had different inlet/outlet positions.
-Micah
05 GTO 6.0
85 Yamaha RZ350
PostPosted: Tue Jul 20, 2010 4:04 pm
got my radiator back today, there was 10 lbs of buildup in the darn thing, but on the upside i have a practically new radiator now. who knew weight reduction was this easy??? :lol:
PostPosted: Mon Aug 30, 2010 8:03 pm
I bought a 7"x12" oil cooler with a 400cfm fan on it and mounted it to the grill mostly out of the way of the radiator. My heater hoses needed replaced anyway. I put tees in the heater supply line before the heater shut-off valve and in the return line and ran hose to the new "auxiliary radiator". Results: Runs a steady 180, before would get up to 215. 25 ounces of extra coolant. Note: all the heater hoses are 5/8" except the one you have to pull the front passenger side tire off to get to. Its 3/4" on the bottom 5/8" on the top. The fan is on a switch which is only hot with the ignition on. I'm going to wait and see if it has warm up problems in cold weather before putting a shut off valve in the supply line.
1980 4x4
