It is currently Mon Jun 22, 2026 3:00 pm
Post new topic Reply to topic  [ 111 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: S-10 build
PostPosted: Fri Jul 09, 2010 6:49 pm
it's not raining!!!!! :lol:
PostPosted: Sat Jul 10, 2010 4:30 am
And im at work . Just my luck .
PostPosted: Sat Jul 10, 2010 10:29 pm
damn it!!!!!
PostPosted: Mon Jul 12, 2010 7:31 pm
Well i got the 2.5 out and the mounts bolted in . Only 2 of the 3 bolts are accsssible and they are a pain to get in so welding the mounts is mansitory in my opinion . I cleaned up the frame with my 4 " grinder and a wire wheel so i can haul it down to the race car shop and have them welded . I'll get the motor in when i finish the mounts . Im going to see if he has a panish hammer for an air chisel and have the floor flange messaged while i got it over there . Here are a couple of pics i'll add some more later .
PostPosted: Mon Jul 12, 2010 8:49 pm
Here are the motor mounts in the hole . Also got the axle shafts in today .
PostPosted: Mon Jul 19, 2010 9:02 am
hey do you want to sell some parts of the old 2.5?
A.j.
PostPosted: Tue Nov 30, 2010 5:45 pm
Hey guys i haven't updated this in a while . The S-10 turned out to be a rust bucket . Both the cab corners were gone the rockers had bubbles and the winsheild frame sealed the deal . I ended up trading it even up for a 78' Nova . Both were rollers . The Nova is not perfect , but way better than the S-10 only needing the passenger side quarter extention replace . The car has actually been setting in a field in Bryan / College station area since 92' . It is still customized from the disco era . Anyway this is what i started with .
IMG]http://i47.photobucket.com/albums/f151/hotrod80/1978%20Chevy%20Nova/DSC01281-1.jpg[/IMG]
PostPosted: Tue Nov 30, 2010 5:46 pm
Well i took a couple of pics today . Got the old lower quarter off and the rust cut out . Fit the new one back in and welded it out . Also got the first and second skim coats over the repair . Here are the updates . The car is supported under the frame , so suspentuion is at full droop .
PostPosted: Tue Nov 30, 2010 9:07 pm
Body work isn't complete yet and you got nitrous on it all ready... i love your priorities hotrod looking good sir, keep us updated.
PostPosted: Wed Dec 01, 2010 4:43 pm
Hey, I got one of those! I have been taking care of this one for my daughter for 2 years now. It was a father son project that I got after the son graduated college. It is in no way fast though, which is good for a daughter. It has a 250/6 with a single barrel carb with Turbo 350. My daughter wants something different now so I am getting ready to sell it off.
I know yours is faster!
PostPosted: Sun Dec 05, 2010 9:08 pm
Well i got the quarter blocked down and pretty straight . Most of the car is blocked and primered . Made some headway on the motor and it is closer . Finished up some small stuff like bolting in the crossmember , trans mount , shifter cable and adjustment . Got the lines bent and flared for the line lock . Pulled the bumpers for paint and im preparing them for the bracket and brace diet . I also got some trailer lights from harbor frieght it make the tail lights work . My backs are gone , so im building backs from sheetmetal that will bolt to the bezel bolts . Anyway here are a couple of pictures . I'll try and get some better ones up tommorow .
PostPosted: Mon Dec 06, 2010 3:39 pm
Looking good sir, I wish i could get body work and priner done that quickly.
PostPosted: Tue Dec 07, 2010 10:04 pm
Well heres todays progress . Most of the body work is done . I got about a day left then more block time . My wife is liking the primer Grey and i already bought the paint . I also put the bumpers on a diet today looking like 35 # i got out . Also moved the front bumper in . Anyway here are the pics .
PostPosted: Wed Dec 08, 2010 6:38 am
Is this still the 9/16" motor?
PostPosted: Wed Dec 08, 2010 12:21 pm
O.K i'll bite , What's a 9/16" motor ?
PostPosted: Wed Dec 08, 2010 2:21 pm
3 9/16 stroke...thought that was what you were building for the Luv. We have run a few of them in modifieds...wondering how one would do on a strip...
PostPosted: Wed Dec 08, 2010 4:34 pm
LMAO... i'm glad i have my decoder ring for this one...hahahahahahahahaha!
PostPosted: Thu Dec 09, 2010 5:34 am
Pretty common terminology in cubic inch limit classes :)
PostPosted: Thu Dec 09, 2010 8:56 am
3 9/16" 350= offset ground 350 large journal with 2" smal journal rods and a not decked block to make up for the offset . 362 or 364 i believe .
PostPosted: Thu Dec 09, 2010 4:26 pm
yes..is that not what you had going together for the s10?
