It is currently Thu Jun 25, 2026 1:42 pm
 Post subject: New Bucket Seats
PostPosted: Sun Jun 13, 2010 7:52 am
What will fit in the Luv for buckets? The bench in mine is trashed and I think I want to put in buckets.I was thinking S-10 or Camaro. Any thoughts or suggestions?
 Post subject: Re: New Bucket Seats
PostPosted: Sun Jun 13, 2010 1:27 pm
you can get anything to fit in there so long as you make the right modifications.
if you are looking for an easier way to install buckets, find some seats that have flat mounts and that will make it that much easier to install.
checker sells some for 150 and they are leather seats. if not, just go to a junk yard and start looking. just keep in mind your clearances for seat belts
PostPosted: Tue Jun 15, 2010 9:42 pm
I have 05 Tiburon bucket seats in mine. They fit to the floor pretty good.
PostPosted: Tue Jun 15, 2010 10:15 pm
Those look good in there!
PostPosted: Thu Jun 17, 2010 7:14 pm
I took a pair of bucket seats out of a 90/91 Mitsubishi Eclipse.
They are a little tall, but comfortable. I had to make spaces for one mount on each of the seats.
**Note: One thing to be very careful is the brake/fuel lines under the cab. I came close to one with one of the new bolt holes I drilled out.
PostPosted: Wed Jun 23, 2010 8:46 am
Thanks. I had to make a couple spacers for mine to.
PostPosted: Wed Jul 07, 2010 4:13 pm
I put in buck seats in my 79 and put the frist hole in with the frunt hole near thedriver door and the rest went in with no truble. henry
