It is currently Thu Jun 25, 2026 9:35 am
PostPosted: Mon Jul 05, 2010 8:50 pm
Guys Does anyone make a cam for the 1.8 so you can get more RPMs out of the little bugger? I am maxed out at 75 mph and it sounds like a sewing machine! I know I can change gears too but what out of? What is the stock gear ration for a 75 2wd?
PostPosted: Tue Jul 06, 2010 12:15 am
try delta cams in Washington... $65
PostPosted: Tue Jul 06, 2010 12:25 am
2WD pups 81/87 with the diesel are mostly 3.73 and a few are 3.42
pups that are 4WDs or are with auto trans in 81/87 are 4.11s
troopers 84/87 are 4.55s and will fit.
your luv should be 4.11s that was very common.
sence your getting to 75mph i don't think you have 4.55s :lol:
though a few where 3.73s
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Tue Jul 06, 2010 5:02 pm
Ctmndu
Do they have an rv or bigger cam? Can you post a link?
Thanks Guys!
PostPosted: Tue Jul 06, 2010 8:32 pm
http://www.deltacam.com/
not sure what mine is and they guy i got it from cant remember what it was ... but it looked like it said 270 on it but was hard to read...
PostPosted: Tue Jul 06, 2010 8:42 pm
Did you get a profile card?
PostPosted: Tue Jul 06, 2010 8:56 pm
i got it in a used motor that was beefed up already but had a bad block
PostPosted: Tue Jul 06, 2010 9:17 pm
Give Delta a call, tell them what you want, they will suggest a cam grind. For the 2.3/2.6 engines a 260 is a high torque at lower rpm grind, the 270 gives more hp at higher rpms, sounds like the 1.8/2.0 grinds are similar. You may have to send them an old cam to re-grind, ask.
Some early LUVs came with 4.56 gears, you need to determine whether yours has them or 4.10's- by far the most common over the years- then you can determine what would be the best ratio to change to.
PostPosted: Wed Jul 07, 2010 11:46 am
Well I gave them a call and I need to send in a cam for them to weld up..no blanks. They also want the rockers(followers) for resurfacing. Any body got a cam and followers for 1.8 they want to get rid of? I need to keep mine running as long as possible.
PostPosted: Thu Jul 08, 2010 4:08 pm
Your '75 should have a 4.56:1 rear axle. The 4.11s didn't show up until '76.
-Micah
05 GTO 6.0
85 Yamaha RZ350
PostPosted: Thu Jul 08, 2010 9:53 pm
I will have to do the rotation test and figure it out. The old cam to use as a blank might be a headache.
