It is currently Sun Jun 28, 2026 8:41 am
 Post subject: Thermostat
PostPosted: Thu Jun 17, 2010 9:47 am
can the stck motor be run with out a thermostat or will it hert the motor? i have heard people will sometime not use them and then others said you must... wanting to know because of the intake i am making... one way will be easy the other a little more money
 Post subject: Re: Thermostat
PostPosted: Thu Jun 17, 2010 9:59 am
Yes,it can be run without the thermostat,but it might cause overheating issues if the water is flowing through the system too fast.
Usually some sort of restriction is needed to slow down the water flow so that it has time to transfer the excess heat from the engine to the radiator.
In my race car(circle track) I use a flat washer with about a 1/2 inch hole in the center for flow restriction instead of a thermostat,but I don't have to worry about running in cold weather either.
PostPosted: Thu Jun 17, 2010 10:26 am
and my thought was what about the cold weather.... we are doing a mock up with one but like i mentioned would be easier with out... but like the manufacture said if it is for resale it needs to be idiot proof ... so they cant blame us for any motor problems... his words not mine, dont want anyone thinking we are calling them idiots... any more thoughts on pros an cons... thanks guys
PostPosted: Thu Jun 17, 2010 10:49 am
I would definately design it for use with a thermostat. 8)
PostPosted: Thu Jun 17, 2010 11:00 am
I vote for thermostat as well, not only does it help regulate the speed at which the coolant flows, it also helps prevent over cooling which is bad for an engine. Maybe no so much with a carb'd engine but fuel injected engines will run too rich if they aren't fully warmed up.
1975 Project LUV
It's ALIVE!
PostPosted: Thu Jun 17, 2010 11:15 am
While most cases you can run without a thermostat, over all, you are better off with one, getting faster warm ups.
PostPosted: Thu Jun 17, 2010 11:24 am
For What Its Worth....
I use one in all competition motors that I build.
all the Builders that taught me to build use thermostats.
it just seems foolish to not have one, But I will advocate that you drill two 3/32 holes in the thermostat to aid in bleeding and prevent overheating in case of failure.
A.j.
PostPosted: Thu Jun 17, 2010 12:17 pm
thanks guys... after talking to the guy more in the UK we decided to go with the thermostat ... he will mock it up and send me pics next week for approval... thanks again for the input...
PostPosted: Thu Jun 17, 2010 7:04 pm
Couldn't a thermostat be mounted in a sleeve of some kind and then the sleeve mounted in the upper radiator hose? Yep, I know some machine work would be needed to fabricate the sleeve, but it would allow the intake to be made without a thermostat housing.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Thu Jun 17, 2010 11:45 pm
They make and sell these already.
1975 Project LUV
It's ALIVE!
PostPosted: Fri Jun 18, 2010 5:09 am
Well Ctmandu, that is an option to avoid the thermostat housing. Even though I won't be needing one, give us some info and pics of what you came up with when you can.
Rick
Loranger, La
PostPosted: Fri Jun 18, 2010 9:45 am
will do...
PostPosted: Sun Jun 27, 2010 1:23 pm
Woops I thought I posted this in my last post:
http://www.summitracing.com/parts/MEZ-WN0072
1975 Project LUV
It's ALIVE!
PostPosted: Sun Jun 27, 2010 2:00 pm
Expensive, but nice! Does this help with your design/cost options?
Rick
Loranger, La
PostPosted: Sat Jan 29, 2011 12:04 am
would anyone be able to tell me if these performance thermostats by JET are any good? i'm looking to get one and this was recommended to me. or is there something better i can get?
______________________________________
1999 jeep grand Cherokee Limited
Eclipse CD7000
1995 Mazda Protege
Eclipse CD7100
PostPosted: Sat Jan 29, 2011 6:37 am
I use these on SBC-
Water Outlet Restrictor Kit Moroso Performance 63440
SKU: 63440
Water Outlet Restrictor Kit Moroso Performance 63440 3 Restrictor Plates - 5/8 in./0.75 in./1 in. ID - 2 1/8 in. OD - GM V6/V8 Eng./Ford 260-302/351W Eng. - Anodized Aluminum
Price: $6.61
http://paceperformance.com/i-6089987-wa ... 63440.html
Users browsing this forum: Baidu [Spider], Majestic-12 [Bot] and 60 guests
