It is currently Mon Jun 08, 2026 12:16 am
 Post subject: Lucked out!
PostPosted: Fri Jun 11, 2010 11:12 pm
ALL RIGHT!!!!
I found a Luv truck trailer at the scrap yard and found ALL the parts i need to fix on my truck at the moment.
I'm gonna pull the springs, Fuel tank, and vapor tank and get them installed on the truck.
my question is this.
what do i have to do to the springs before i install them? should i grease the leafs or something?
the u bolts might be replaced if i damage any of them. I'll also get the pinion seal changed out while i'm back there.
Advice is greatly appreciated
 Post subject: Re: Lucked out!
PostPosted: Sat Jun 12, 2010 12:22 am
Hope this helps-
PostPosted: Sat Jun 12, 2010 8:17 am
Hi Figs, do you still need the air pump and rail?
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Jun 12, 2010 11:41 pm
the rail, yes, the pump no. i found it sitting in a lonely box in the corner of the shed.
i knew i kept forgetting something!
PostPosted: Sun Jun 13, 2010 8:33 am
OK, PM me your address and if you need the hoses or not and I'll send it out to you.
1981 Luv 2WD
1981 Luv parts trk
