It is currently Wed Jun 10, 2026 10:00 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 11, 2010 3:42 pm
4bt weighs a ton!!! And it is tall as the plumbing for the turbo goes over the top of the engine. There has been talk on using the ISUZU engine in things... Check on the 4bt forum, or the yahoo group which I am too.... I have 2 350 olds diesels.. 1 with around 500,000 miles on it. Problem is getting some parts... I can not find oversize rings... every now and then a set will show up... It was even in a ford truck at one time... You have to use what you got some times.
PostPosted: Thu Jul 01, 2010 11:28 am
Whats your plan for the steering?
I have yet to figure out what to do myself.... im doing the same except I used toyota springs.
A.j.
PostPosted: Thu Jul 01, 2010 6:07 pm
olds 350 diesel???
not a bad idea =)
i do have some trouble trusting the chevy diesels for the blocks but 500,000 on an olds diesel doesnt sound bad at all. how hard are those to come across?
PostPosted: Sat Jul 17, 2010 12:19 am
A.j.
For now? The stock steering for the Chevy the 10 bolt came off of, steering box and all. Eventually I'll go crossover, and eventually eventually I'll go full hydro.
PostPosted: Tue Jul 20, 2010 12:45 pm
You need the later "DX" engine. The letters are cast into the side of the block.
NEVER NEVER reuse the head bolts!!!!! Use new ones or ARP bolts.. Both of mine have them. All factory replacements were supposed to be DX engines. You can find them sometimes.
PostPosted: Sat Oct 30, 2010 11:09 pm
Well this sucks, no time and no money. Just dreams. Hopefully she'll be out ripping shit up by the time the snow melts... If it ever snows...
PostPosted: Sun May 22, 2011 11:48 pm
What year trooper upper controll arms and ball joints to get that extra lift in the front of my luv
PostPosted: Tue Jan 24, 2012 10:23 am
Heres how i had to build a cross member for the front shackles. I used toyota rear springs, and they are long enough to were i needed that extra coupl inches out front to fit them.
Hold my beer and watch this!
PostPosted: Mon Jun 04, 2012 8:40 pm
do you still have the control arms if so i am interested
