It is currently Sat Mar 21, 2026 8:04 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Wed Mar 24, 2010 12:18 pm
Got myself a Dana 44 full width and I'm going at it. I'll be running leaf springs on all four corners, and probably a full width 14 bolt in the rear. Woot woot!
If anyone needs any IFS components, I've got em in good shape. And if anyone wants a little lift for the front of their LUV, I've got the correct Trooper upper control arms and ball joints so you can do the ball joint flip and the arms themselves get you an inch or two. So overall, about 2 and 1/2 to 3 inches lift.
PostPosted: Tue Mar 30, 2010 12:37 pm
Progress.
PostPosted: Wed Mar 31, 2010 10:20 pm
Banishment Pending
Looking good 8)
I might be interested in the Trooper UCA's and BJ's
PostPosted: Sat Apr 03, 2010 4:27 pm
nice how exactly are you adding the leaf springs on the front? i've got a system from a 75' K5 blazer and was wondering what would be the easiest way to put it on my LUV.
PostPosted: Mon Apr 05, 2010 12:15 pm
I'm using the rear springs out of another LUV, but since the frame Y's inboard in the front, I'll be mounted the spring hanger in the rear on the underside of the frame, and the shackle up front outboard. I haven't seen anyone do it like this in the past, but I want parallel springs.
I'll letcha know how it works out.
PostPosted: Sat May 29, 2010 2:42 pm
Just got myself a 14 bolt and 63" springs.
PostPosted: Sat May 29, 2010 3:30 pm
thats gonna be one unique luv when all is said and done i would defiantly try sending pics to petersons 4x4 and a few 4 wheeling mags see fi you can get a feature or a mag pic
PostPosted: Sat May 29, 2010 3:37 pm
huh a luv on fullsize running gear thats going to be interesting
which engine are you running??
axles and wheels like your running would defiantly merit the use of a SBC :ebiggrin or even a BBC V8 8O
PostPosted: Sat May 29, 2010 8:10 pm
Currently I'm going to run the 1.8 til it dies while I get the suspension tweaked to perfection. Then, when it does die, I'd like to swap in a diesel engine and a Dana 60 and some 42's.
But for now its actually a 10 bolt up front, and wheelbase will be about 104", perfect.
PostPosted: Sat May 29, 2010 8:53 pm
runnin it till it dies might take a while 8O
PostPosted: Sat May 29, 2010 9:49 pm
I'm plannin on running 37.5" tires. So I may have to have a heavier right foot than normal. It shouldn't take long.
PostPosted: Sat May 29, 2010 10:40 pm
:lol: nice yeah might not take long X^D what sort of diesel motor are you looking into swapping? a diesel pup/luv 1.8? or something bigger
PostPosted: Sun May 30, 2010 12:33 am
Well, I wish Chevy and Dodge wouldn't have discontinued their 4.5L (or something like that) diesel 1/2 ton project, or Isuzu would ship some of those damn 3.5L diesels over here.
Anyways, it'd be the biggest small diesel I can find, or the smallest big diesel. More than likely I'll opt for the smallest big diesel... Anyone know if a 6 liter will fit in the LUVs engine bay? :)
PostPosted: Mon May 31, 2010 3:25 pm
Anyways, it'd be the biggest small diesel I can find, or the smallest big diesel. More than likely I'll opt for the smallest big diesel... Anyone know if a 6 liter will fit in the LUVs engine bay? :)[/quote]
i remember seeing a 6.1L into a mini-truck swap somewhere recently not sure where or which specific model of truck it was it was a while ago
it defiantly wouldnt be an easy swap but it would be awesome once it was done! and a midsized diesel would turn a set of 42's on the 44 and 14 bolt real nice 8)
PostPosted: Mon May 31, 2010 9:53 pm
Know of any diesel motors sold in the US from 3.0L to 5.0L?
PostPosted: Tue Jun 01, 2010 9:28 pm
The Olds 5.7 and GM did build a V6 diesel that was a 3.8 or 4.3 i don't remember for sure but i think it was the 4.3. There is also the Perkins diesel used in some Rangers and S-10s then there is the Isuzu diesel in the NPR cab over trucks that is a 4 cyl then there is the 6 cyl one .
PostPosted: Wed Jun 02, 2010 12:58 pm
Do you know what they put that 4.3 in?
PostPosted: Wed Jun 02, 2010 9:24 pm
They were in early 80's Olds cutlass sirius Wrong wheel drive and some Buicks i think but after looking at them i think they would be easy to convert to rear drive if you find one.
Another one you might think about is the 4BT Cummins (same as the Dodge but a 4 cyl ) these were in a lot of step vans and had TH 400 hooked up to them.
PostPosted: Mon Jun 07, 2010 5:26 pm
any news on the swap 8O
PostPosted: Fri Jun 11, 2010 3:34 pm
The 4.3 came as both as a FWD and RWD versions...
