It is currently Mon May 25, 2026 12:37 pm
 Post subject: drop spindles
PostPosted: Tue Apr 27, 2010 9:19 pm
hey wondering if anybody makes dropped spindles for the luv. or what other dropped spindles will fit without changing the complete front end.
 Post subject: Re: drop spindles
PostPosted: Wed Apr 28, 2010 8:31 am
if i rem correct you can use toyota and jus drill out the hole so that the luv ball joint....but to answer your first ? no they dont make drop spindles for a luv
Epic Fabrication.
KAOS
PostPosted: Thu Apr 29, 2010 2:20 am
oh ok cool.what sort of toyota spindles do you use? as much info i can get on this the better
PostPosted: Thu Apr 29, 2010 7:59 am
could always swap to S10 spindles and get 5 lugs as well.....
A.j.
PostPosted: Thu Apr 29, 2010 3:23 pm
i have read about that but im trying to keep it down to just changing the spindle if i can. im in australia so parts from an S10 and the likes i would have to import from the states and postage is a big killer even with small things so id hate to say what it would cost me to get them here
PostPosted: Sun May 02, 2010 1:42 am
is anybody able to tell me whether its the tacoma spindles you use? if so do you know if the tacoma uses the same spindles as the australian hilux
PostPosted: Sun May 02, 2010 5:45 pm
They don't make drop spindles for a luv, only thing you have to do if you are wanting to keep it 6 lug is to Z the frame
PostPosted: Mon May 03, 2010 2:59 am
front will only be static for a wjhile. have to do a brake upgrade so was thinking if the toyota spindles fit i will use toyata brakes 2. not fussed about 6 lug just hard to find chev parts in aus
PostPosted: Mon May 03, 2010 3:57 pm
early toyota spindles lie late 80 to like a 94 i believe
Epic Fabrication.
KAOS
PostPosted: Mon May 03, 2010 4:33 pm
are these a tacoma or what? trying to get an answer from belltech whether they are the same as our hilux in aus
PostPosted: Tue May 04, 2010 4:06 pm
sould jus be called a toyota pickup..should be the years before the tacoma
Epic Fabrication.
KAOS
PostPosted: Wed May 05, 2010 3:08 am
thanks for all you help mate. pain in the ass not being able to find parts easily here. gota try workwith what is easy to source.
PostPosted: Tue May 25, 2010 3:06 am
decided to go for s10 spindles. do these work with stock brakes etc? also would i be best to go for chassis tech belltech or summit brand spindles?
PostPosted: Wed May 26, 2010 7:37 pm
now the s10 spindles wont work with stock arms...
Epic Fabrication.
KAOS
PostPosted: Thu May 27, 2010 3:37 pm
oh ok.i thought that these were the common onew to use on luvs with a 5 lug conversion. what arms would need to be used or what sort of spindles would work?
PostPosted: Tue Jun 15, 2010 9:58 pm
the s10 spindles are common but ull have to get some control arms from mike..or else jus find the 90-94 toyota spindles and use them and the hub and brake calipers
Epic Fabrication.
KAOS
