It is currently Tue Jun 16, 2026 3:14 am
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: EJ20 LUV
PostPosted: Thu May 13, 2010 7:45 pm
Codym wrote:
Started to biuld out the motor yesterday. These motors still look fun to me.
Today I will be putting the new cams in and getting the gapping right.
8O
PostPosted: Fri May 14, 2010 12:11 am
love4theluv wrote:
now that is a badass swap,
i have considered alot of different engine swaps but that is by far the best i have heard so far! how much has that setup run you so far??
well how much was the engine and transmission combo alone?
Well the engine was $150 with a spun bearing.
Machining & balancing with forged internal was about $2100
Gasket seals pumps belts....... $650
Trany was $860
ECU and wiring $225
That is most of it so far still need a few more things
Turbo $1000
Injectors $500
Tuning $600
I hope it will fit I'm still not a 100% that it will. :?
PostPosted: Fri May 14, 2010 7:01 am
holy hell talk about you big budget builds!
i dont see any reason why it wouldnt fit there is quite a bit of area under the hood of those lil trucks... man... those subies sure do scoot around pretty quick and have a great sound to em especially with turbo, if i had that much money to throw at my LUV i would be considering a similar swap but as it is now im more concerned with getting a 5 speed for my G180 and eventually doing a custom turbo setup (buy a lightly used turbo and adjustable BOV and make my own turbo exhaust manifold and 2 1/4" exhaust system) add a G161 head to boost compression a bit more and hopefully get that lil truck over 125 on the highway.
yay for cheap budget builds
hmm...LUV/Subaru hybrid LUVARU :idea: that should be quite the get up and go rig... lightweight horizontally opposed high performance engine in a LIGHT stylish LUV body. sounds like a dream
hmm you should look into getting some WRX LUV decals made
LUVARU :lol:
PostPosted: Fri May 14, 2010 11:49 am
SubiLuv
LuvBaru
EJ20Luv
Are a some that I have come up with.
PostPosted: Fri May 14, 2010 4:59 pm
EJ20T LUV if your gonna turbo it :lol: show off even more
PostPosted: Sun May 16, 2010 6:35 am
have you already mocked the drivetrain in?
how much boost you planin on runnin? im gettin ready to do the comitec gasket swap and am gonna set for 15psi. these trucks are so light you dont see max boost for too long unless your seriously mashing on them.
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Sun May 16, 2010 11:00 am
I have not mocked any thing up besides doings some measurements but the engine sould be finished by nextg weekend so then I will drop it in and see how it is alll going to fit.
I plan on max boost of about 25-30 psi on E85 for racing and 20 for day to day.
My wagon with stock inturnals that I drive evey day is running 18 at about 4800 rpm with peak 280whp
The truck is just going to be stupid. I think as so as I hit full boost the truck is just going to go sideways. :lol:
Next year I will do the suspension to try to get the power down and striaght.
PostPosted: Sun May 16, 2010 2:38 pm
yeah keeping that power in a straight line is gonna be a challenge but thats gonna be savage when its done 8)
i just have one thing to say on that topic coilovers
PostPosted: Sun May 16, 2010 2:54 pm
stupid is right :lol:
i built a 88saab 900t that pushed 29psi thats awesome boost. i thnk i could get 20psi once i get a chiped ecu and switch to some 550cc injectors. what are you runnin for a FPR and pump combo
PostPosted: Sun May 16, 2010 5:47 pm
I'm not sure which FPR or pump I'm going to use but I'm going with a inline pump I know that much and it is going to be a big one becasue I will be running 1000cc injectors.
PostPosted: Thu May 20, 2010 6:09 am
any updates on the subi luv?
PostPosted: Thu May 20, 2010 1:13 pm
I have had some troubles with the gapping of the cams. Get the right info and then getting the right shims. The shims should be in on friday so then I can start moving foward
PostPosted: Thu May 20, 2010 3:44 pm
8)
nice i cant wait to see the finished project, you gotta get a video posted of it when its done :!:
PostPosted: Mon Jun 14, 2010 11:33 am
Well the motor is almost done need to put the timing belt and timing belt cover on. Then I'm going to just sit the intake on and bolt the tanny to it and start trying to put the motor in and building the mounts.
PostPosted: Mon Jun 14, 2010 3:03 pm
you stilll lookin for a turbo. i have the stock garret style turbo from my current luv sr20det. i am have a t3/t4 hybrid i am installning this winter and would be willing to give up the stocker
PostPosted: Tue Jun 15, 2010 3:44 am
No thanks I'm looking for a little bigger. The FP 68HTA is what I'm looking at but still doing some research.
http://store.forcedperformance.net/PROD ... 68HTA.html
PostPosted: Tue Jun 15, 2010 1:00 pm
I offer custom turbos, anysize you want if you need help.
A.j.
PostPosted: Fri Jun 18, 2010 12:37 pm
Long block done :D
I started to put the motor in and it looks like the battery tray needs to go and the E brake cable might be in the way of the up pipe for the turbo.
PostPosted: Fri Jun 25, 2010 8:53 pm
So I started to put the motor in today. Had to massage the inner fenders a little and had to pull the steering column to get the motor in.
It still sits a little high. The mounts for the steering rack are in the way.
I also made some plugs for the fronts axles holes in the tranny.
PostPosted: Fri Jun 25, 2010 9:49 pm
Dang this is a cool project!!!!
