It is currently Wed Jul 01, 2026 12:04 am
Post new topic Reply to topic  [ 161 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
 Post subject: Re: R1 Carbs on G200
PostPosted: Thu May 13, 2010 5:00 pm
You just need the plates right. What is the thickness.
PostPosted: Thu May 13, 2010 7:16 pm
plates are 3/8... se how much for plates and then plates and runners... thanks
PostPosted: Tue May 18, 2010 11:16 am
i just got off the phone with a company in the UK that builds intake manifolds, i will be sending stuff over there this week for them to build the prototype... as no one here wanted to try to make them and i dont have a good aluminum welder yet but may come fathers day... so just a little update...
PostPosted: Tue May 18, 2010 12:22 pm
NICE 8)
way to move ahead of the curve, start fabing some intakes and you can make a killin in the hardly existant market
PostPosted: Tue May 18, 2010 4:11 pm
i am tired of the guys here , almost took a month to do the dam flange for the intake ... way to slow... here is some of the work they do...
PostPosted: Tue May 18, 2010 4:37 pm
So my work suck and they keep pushing me to the side.
But this is a friend of mine that does a lot of cool stuff and is state side.
http://www.xcessivemanufacturing.com/me ... =36&step=2
Just tell Rich that Cody from DTI sent you.
PostPosted: Tue May 25, 2010 7:59 pm
I'd just like to throw my hat in the ring and say my buddy and I run a waterjet shop (Omax 55100 with Tilt-a-Jet) and I might be able to give you a competitive price on the flanges. We can cut practically anything up to 6in thick and maintain .005" tolerance.
Plus we also do precision welding (my boss is an incredible welder) at the shop too, but the weld shop is kinda swamped right now. Also, I have a TIG at home. I've just completed my TIG course at the CC and sent in my cert plates for aluminum and stainless, the welds might not be the prettiest but I'm cheap and could have a quick turn-around. My stainless/mild welds are really nice, but my TIG at home lacks pulsing so they might not be as pretty in aluminum. PM me if you want to discuss it further.
1975 Project LUV
It's ALIVE!
PostPosted: Fri Jun 18, 2010 4:13 pm
the intake is being worked on now they are back from vacation and i picked up the gear wheel with press on adapter i had made today..
PostPosted: Mon Aug 02, 2010 2:12 pm
ok a little update. i have my test intake done. well play with this a bit and make any mods that need to be done then will have a price for them for you guys...
will get pics up when i get home tonight...
PostPosted: Mon Aug 02, 2010 11:12 pm
here are some pics.
Image Image
PostPosted: Wed Aug 04, 2010 2:37 pm
let me be the first to say. THOSE LOOK SWEET
you are using 40mm R1 carbs right? do you know the jetting specs on them?
PostPosted: Wed Aug 04, 2010 2:40 pm
you oughta do a dyno run and see what kinda power those things are puttin out 8O
PostPosted: Thu Aug 05, 2010 12:23 am
all stock jet but the mains. they will go to 1.7 and start from there to see if i need to go up or down in size
PostPosted: Fri Aug 06, 2010 12:56 pm
8O awesome, if i can find a cheap set of R1 carbs floating around craigslist or ebay for a decent price i may have to buy one of those manifolds from ya.
PostPosted: Sat Aug 07, 2010 10:06 am
Ok, let me know... I found mine on eBay but have seen them go for $25 to about $200 ... also you can see if you can find any bike breakers around and see what they will charge
PostPosted: Sat Aug 07, 2010 2:08 pm
very true.
wouldn't basically any 40mm quad carb setup work? most of the Japanese crotch-rockets have similar carb setups and so do a lot of the European bikes. just comes down to tuning the jetting.
have you decided how much your charging for the manifolds?
PostPosted: Sat Aug 07, 2010 10:40 pm
No price yet ... I will make some changes to theses and have another set made but also try to do so locally to save money...
As for carbs they would have to have the same spacing as the R1 to work on the manifold or you may have to modify the carbs to fit... everyone recommends the R1 for this type but yes you could use any bike carbs
PostPosted: Mon Aug 09, 2010 10:26 am
you dont think there is going to be a large reduction in torque and power?
remember by going to an individual runner intake your going to encounter alot of pumping losses.
Id be worried the stock motor would trip all over itself with that much carb.
A.j.
PostPosted: Mon Aug 09, 2010 11:40 am
not sure as I have seen this done on 1300 to 2600 cc inline 4 motors and all liked the R1 carbs except the 2.5 and 2.6 motors as they needed a bigger car, (42/43mm) not the 40mm R1...
Hope to find out soon. I know guys in AU have had 45mm duel Weber on there’s
PostPosted: Tue Aug 10, 2010 12:25 pm
i looked into it a bit. the R1 carbs are running a 1000cc engine at 16,000+ rpm and making massive power. rejetted for a 1800cc engine running 2,000-6,500 there would be no shortage of power. with a reground cam to utilize the air you are taking in the R1 carbs are going to be beastly :ebiggrin 8O :lol: :D
