It is currently Tue Jun 30, 2026 1:50 pm
 Post subject: Ujoint Question
PostPosted: Tue May 04, 2010 4:27 pm
I have done a V8 swap and I currently have a rearend out of a 2000 S10 that has the flat face yoke, and I have a 1979 camaro driveshaft that is not installed. The junkyard gave me the wrong driveshaft for the rearend I have and I am looking to rebuild the rearend any way, does anyone know what type of yoke to use the stock size u-joint for the camaro I would need to bolt up the camaro driveshaft. I can not find a list of what model year used what u-joint size or type. Someone please help. Any advise or idea at all would be great.
would something like this work is what I am asking:
http://www.dennysdriveshaft.com/p1051_gm_3r_series_pinion_yoke_for_7.625_inch_10_bolt_with_27_spli.html
 Post subject: Re: Ujoint Question
PostPosted: Wed May 05, 2010 11:01 am
All you should have to do is call their tech support, tell them what you have and they should be able to help you out. Your FLAPS could along time ago when they had real parts people, even the local dealer parts deartments but all the old parts guys have retired or a local driveline shop should be able to help. I have found parts are cheaper than the FLAPS.
PostPosted: Wed May 05, 2010 11:34 am
Thanks for the fast response, as always PapaG to the rescue! :P
Users browsing this forum: Baidu [Spider] and 30 guests
