It is currently Fri Mar 20, 2026 4:27 pm
PostPosted: Sun Apr 11, 2010 1:53 pm
I forgot to tell y'all that I am new to the forum and bought my 1980 LUV for $600 running and driving and 4x4 works great, entire truck has only 104k miles. It only has 2 spots of rust, one right below passenger door which I'm going to fix as soon as i get my welder fixed..... and one on the front passenger cab mount bolt hole, which I can't fix til i get my welder fixed. I've yanked the engine which I am almost done rebuilding just need to get a valve job done. I'm not going to put the engine back in until I get all the bushings and other misc items replaced on the front end plus putting rhino on the frame. :ebiggrin I also plan on putting a '72 K5 blazer's axles on the front and back but keep the original engine, I know sounds kinda dumb but it'll be worth it. I don't have any pics right now unfortunately but I will try to get some posted soon. I'll keep y'all updated on my progress.
When in doubt floor it. If you can't floor it then you've doubted yourself.
PostPosted: Fri Apr 16, 2010 8:10 pm
Welcome to the site.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Apr 18, 2010 8:40 pm
Sounds a lot like what I'm doing, goodluck friend.
