It is currently Mon Jun 08, 2026 12:35 am
PostPosted: Sun Apr 11, 2010 6:33 pm
I started working on the LUV since it broke the oil pump and this is what I saw. The belts were miss aligned so I took a closer look and to my surprise I can see balancer sticking out ready to fall off.
PostPosted: Sun Apr 11, 2010 7:33 pm
Balancer came out by hand. WOW, I got really luck it didn't come off while driving.
PostPosted: Sun Apr 11, 2010 8:45 pm
The belts were probably what kept it on. So, I'm guessing the bolt was gone?
PostPosted: Sun Apr 11, 2010 9:04 pm
I agree. Surprisingly the bolt was still there, came out by hand also. A few more miles I don't think the bolt or the balancer would have been there.
PostPosted: Sun Apr 11, 2010 11:11 pm
Jeez that crazy.
2006 GMC Sierra 2500 HD
PostPosted: Mon Apr 12, 2010 9:09 am
man with all the bouncing up and down i do in the hills, i guess now would be a good time to find out if there is anything wrong with mine! :lol:
PostPosted: Tue Apr 13, 2010 11:22 am
It does not hurt to look things over. Check all your bolts to see if they are tight also.
PostPosted: Tue Apr 13, 2010 9:38 pm
Make sure the hole is not stripped out... I have never had to use any, but you could blue locktite it.
PostPosted: Wed Apr 14, 2010 1:53 am
Will do. I use loctite on everything. Love the stuff. Usually if the bolt is torqued to spec it does not come off.
Users browsing this forum: No registered users and 59 guests
