It is currently Tue May 26, 2026 12:48 am
 Post subject: Disc brake rotors
PostPosted: Sun Apr 11, 2010 11:22 am
I've been racking my brains, and searching like crazy, but didnt found what i wanted
so does any one know if there is a vented brake rotor made for the luv? mine are below spec (and i got them turned anyway) they need to get replaced very soon.
 Post subject: Re: Disc brake rotors
PostPosted: Sun Apr 11, 2010 11:29 am
Ok......
http://forums.luvtruck.com/viewtopic.php?f=7&t=19714
PostPosted: Sun Apr 11, 2010 11:43 am
There's also a thread about trooper discs and calipers on a LUV, trooper discs are vented
PostPosted: Sun Apr 11, 2010 12:10 pm
sorry i guess i didnt put in the right search string...
PostPosted: Mon Apr 12, 2010 8:01 pm
sweet. got the 84 trooper rotors ordered today. hopefully this info will help someone else, so im gonna list some keywords so that it will come up in a search
Keywords :
Disc rotor upgrade, Vented Rotors, Trooper Rotors, Upgraded rotors, brake rotor update, brakes, vented LUV rotors
PostPosted: Mon Apr 19, 2010 1:18 pm
got the rotors today. gonna install later today or tomorrow morning
PostPosted: Tue Apr 20, 2010 8:03 pm
And t thought i was busy working on my truck ---keep up the good work and us informed of your progress.Can hardly wait for your 5sp swap and trust me it was worth it.
PostPosted: Tue Apr 20, 2010 10:32 pm
well, 5spd for my truck will have to wait until i can find a trooper 4wd trans
PostPosted: Wed Apr 21, 2010 6:25 am
Check around the wrecking yards and see if you can buy the whole thing or most of it cause it will have the front upper control arms,power steering,and rear springs to build yours with.
PostPosted: Wed Apr 21, 2010 8:44 pm
ok, so i got my rotors in just a little bit ago.
prior to installing them, i still had the overcut stock luv rotors on there, and while driving i kept hearing what i thought was a wheel bearing going bad.
checked everything a little while ago and found the driver front bearing wasn't tightened enough. tightened it enough to prevent wobble and went just a little past that.
installed new trooper rotors and put everything back together.
went for a drive, and the slight grinding noise is back.
lifted the front and i hear it from the front driver side wheel. i turn it by hand and i can feel a slight drag where it sounds like the rotor is wobbly. these are BRAND NEW rotors! what gives??? i've never had this much noise come from a rotor swap before!
PostPosted: Thu Apr 22, 2010 3:26 am
Check the dust shield it could be bent and rubbing
