It is currently Tue May 26, 2026 12:47 am
 Post subject: cab mounts
PostPosted: Thu Mar 25, 2010 6:09 pm
Can any one help with finding or knowing of what cab bushings will work for a 1980 Chevy LUV 2WD long wheel base. Is there any body that still manafactures correct height body bushings?
 Post subject: Re: cab mounts
PostPosted: Sun Apr 25, 2010 10:20 pm
bump im looking for this info as well
PostPosted: Mon Apr 26, 2010 10:25 am
I used hockey pucks cut down to the diameter needed. I found that regular automotive type bushing was giving me way to much slop and urethane style ones squeaked alot.
best part, is I seriously doubt there will be a shortage of hockey pucks.
A.j.
PostPosted: Mon Apr 26, 2010 4:49 pm
A.j.
whats the easiest way to cut them down and to keep it even and accurate?
PostPosted: Tue Apr 27, 2010 8:19 am
A.j.
I used a 1 3/4" hole saw and cut right into the center, and used the "plug" that comes out of the bit.
A.j.
PostPosted: Wed Apr 28, 2010 5:22 am
very interesting. thanks AJ
