It is currently Mon May 25, 2026 9:52 pm
 Post subject: Upgrade ??
PostPosted: Wed Mar 17, 2010 6:11 pm
Ok so I have managed to find a 2.0 turbo from an 87 impulse. From what I have found on here it should bolt up. Now I have an 80 4x4, what may I have to change to make it bolt up? Motor mounts ect.. I know I have to change the fuel lines and the computer ect but as far as fab work goes what would I be looking at? Has anyone ever posted this swap before? I can't seem to find one. Thanks!
 Post subject: Re: Upgrade ??
PostPosted: Wed Mar 17, 2010 7:09 pm
The 4x4 motor mounts and the 4x4 oil pan, then the wiring and fuel lines...
PostPosted: Wed Mar 17, 2010 8:31 pm
Ok so I will need to put my motor mounts on it and my oil pan and then it should bolt up? I already have an idea where to put the computer, and I did see someone else talking about the rubber parts of the fuel line.
PostPosted: Wed Mar 17, 2010 8:58 pm
I never did it, but it should. the G200 block is the same, turbo or not, I believe. Be sure you use the correct clutch disc for the tranny, not sure if the 5 speed has a different spline...
PostPosted: Sun Mar 21, 2010 1:00 pm
why dont you just swap the turbo parts and no efi? itd be much easier
