It is currently Wed Mar 18, 2026 1:26 pm
PostPosted: Sat Mar 20, 2010 11:44 am
hey guys, i'm still in tucson, and we have uncovered a very unfortunate situation.
i noticed that for every 200 miles the engine runs, we use about a quart of oil. im sure i dont have to tell you, that's not good.
i plan to either rebuild or replace the motor when we get back to salt lake, depending of course on how bad the compression figures are.
i figure that i will need main bearings, piston rings, (and pistons depending on condition) a head gasket set, (intake, exhaust etc.)
what parts will i need to get the rebuild done?
PostPosted: Sat Mar 20, 2010 12:22 pm
Switch to High Mileage oil, and maybe a heaver weight if you need to. People with VW Vanagons have to use xx-50 oil so they do not get the oil light coming on when they exit a freeway and such things, the engines are not wore out. My 40k mile engine in mine Vanagon I use it. STP can help too. I did see a plant factory yard only truck,, use only 90 weight gear oil in the engine. :( .
PostPosted: Mon Mar 22, 2010 11:52 am
i plan to check out the compression figures, but i wont know what they are right now.
for me, changing the grade of oil will only temporarily solve the problem.
i just need to know what parts i will need to replace when i do this. it's been a long while since i did a total engine rebuild
PostPosted: Mon Mar 22, 2010 6:45 pm
You could start with a kit to get most of the items.
PostPosted: Tue Mar 30, 2010 11:28 am
I dont know anybody that has succesfully rebuilt a geo motor. most just pull and drop, as its usually not worth it to try and rebuild.
A.j.
PostPosted: Tue Mar 30, 2010 12:21 pm
Thats what i was hoping i WOULDN'T have to do. i guess that means i better start looking for an engine...
PostPosted: Tue Mar 30, 2010 2:54 pm
:twisted: :twisted: :twisted:
PostPosted: Tue Mar 30, 2010 11:14 pm
Dude. 8O
PostPosted: Wed Apr 14, 2010 8:53 pm
is this a XFI model GEO??
you may know all this, but.....
XFIs are a early 90s only, ALL ARE
2 door,
two ring pistons,
difrent cam,
difrent final gear,
and are all a manual trans, if its a lousy auto trans in a XFI, its a swap.
trying to find one of these to replace one, is near imposable.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Wed Apr 14, 2010 9:11 pm
put a v8 in it lol that will fix it
75-luv mikado-V8 350 soon
PostPosted: Wed Apr 14, 2010 11:24 pm
well, for the moment, the engine is going to get an oil change to a thicker grade like what was recommended, and hopefully that will allow the engine to last us at least until next year. if nothing else, im going to ATTEMPT to use a honda engine and trans as a custom swap. who knows? maybe i will get lucky !
