It is currently Mon Jun 08, 2026 12:35 am
 Post subject: PerTronix Ignitor/Coil
PostPosted: Thu Mar 11, 2010 1:01 pm
I am looking to buy an Pertronix Ignitor/Coil, but I am not quite sure which one to buy or the difference between the Coil I - 1.5 ohm, black, epoxy, 40kV and the Coil I - 3.0 ohm, epoxy, 60 kV, HV Coil. I have a stock 4cyl. motor. Any/All information on the two would be greatly appreciated, thanks!
Weaver, Brett
'74 Luv <3
PostPosted: Thu Mar 11, 2010 8:09 pm
viewtopic.php?f=24&t=17586&hilit=pertronix
PostPosted: Fri Mar 12, 2010 12:17 pm
Talked to the Guy the other day! He told me to use this part # 1643
http://www.vintageperformance.com/retro ... evrole.htm
Hope that helps!
PostPosted: Fri Mar 12, 2010 3:10 pm
Thanks!
Weaver, Brett
'74 Luv <3
PostPosted: Wed Sep 01, 2010 8:27 am
Did you guys ever get the Pertronix installed in your trucks. If so what kit did you end up buying and from who.
76 LUV
PostPosted: Wed Sep 01, 2010 9:44 pm
Dont they still use points on internal combustion engine airplanes?
1980 4x4
